Repairing Nuraphones "Entering Deep Sleep" Broken Capacitive Sensor
  1. Repairing Nuraphones "Entering Deep Sleep" Broken Capacitive Sensor, Grip and twist: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Repairing Nuraphones "Entering Deep Sleep" Broken Capacitive Sensor, Grip and twist: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Repairing Nuraphones "Entering Deep Sleep" Broken Capacitive Sensor, Grip and twist: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • For fixing the "deep sleep" issue, feel for the cup that has a flexible ring (capacitive sensor) around the face-side of the cushion. It should be the right cup.
    • Grip the hard outer shell of the ear cup you want to disassemble.
    • Completely cover the soft padding area with your other hand, squeeze to grip, and twist like opening a jar.
    • Twist the left cup clockwise to open, and turn the right cup counter-clockwise to open.
    It should be the right cup.“ ... that should be in bold, red letters. The sensor is definitely in the right cup. There is no sensor in the left cup, so no need to open the left cup and potentially risking to accidentally tear off the extremely delicate audio wiring.
    Andre Klein - crwdns2934203:0crwdne2934203:0
    Click, click. Edited :) iFixit is a wiki, by the by - feel free to slide in and make edits that are appropriate! I think you've got a fair point, so I added some bold. It is a quick twist for each, though, as I've had mine open many times (I've had to fix this twice on them so far, with infrequent use/long periods of storage). Thanks for the note, in any case!
    Matt Falcon -
  2. Repairing Nuraphones "Entering Deep Sleep" Broken Capacitive Sensor, Remove screws and fold skin back: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Repairing Nuraphones "Entering Deep Sleep" Broken Capacitive Sensor, Remove screws and fold skin back: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Repairing Nuraphones "Entering Deep Sleep" Broken Capacitive Sensor, Remove screws and fold skin back: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove 9 Torx T7 screws from the ring of the cup
    • When reinstalling any plastic screw, insert the screw in the hole and rotate backwards (unscrew direction) with slight downward pressure until you feel a click - that locates the original thread and prevents stripping. Begin screwing it back in where you feel the click.
    • Separate the two halves of the cup, revealing the skin mounting
    • Fold back the skin, revealing the ear cup foam and (if fixing the Deep Sleep issue) the broken wire leading to the capacitive ring
  3. Repairing Nuraphones "Entering Deep Sleep" Broken Capacitive Sensor, Pull the wire through the foam: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Repairing Nuraphones "Entering Deep Sleep" Broken Capacitive Sensor, Pull the wire through the foam: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The capacitive sense wire will likely be buried halfway through the foam. Your job is to get it back through.
    • It may help to squish the foam flat and fish the wire through the smaller, squished distance.
    Bro I recently factory reset my headphone,now when I try to creat hearing profile everytime app showing left eartips not properly seal your ear canal, I did everything I changed eartips of ever size but nothing happened,is it sensor issue? Can you help me how to fix it?
    JuNaid Sheikh - crwdns2934203:0crwdne2934203:0
  4. Repairing Nuraphones "Entering Deep Sleep" Broken Capacitive Sensor, Tin the Litz wire and resolder to ring: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Litz wire has enamel (insulation) wrapping every tiny strand individually. Thus, you need to melt it off the bundle at the tip - it should form a dark brown blob with some smoke, assisted by adding excess fluxed solder (and cleaning your soldering tip while doing so).
    • After you have a tinned segment, you may wish to trim it to a clean, tinned tip (remove fraying at the end), then simply attach it back to the pad on the capacitive ring.
    • You're done! Reverse the disassembly steps to re-assemble.
    Thank you for making this guide, it helped me fix my headphones. I was pretty frustrated that my $399 headphones stoped working after a year and Nura phone did nothing to support, except a discount.
    Lukas Freijd - crwdns2934203:0crwdne2934203:0
    Quick question I’ve never soldered anything I’ve never even really touched an electronic on the inside like with wires and stuff, I’m a capable person so I’m confident I can do this but I need to know can I just like buy a $16 soldering iron or should it be a nicer one I don’t want to get to the point of the soldering and the cheaper iron completely melts something important and I searched for Litz wire on Amazon what kind exactly do I need like what gauge :)
    Michael Ryker - crwdns2934203:0crwdne2934203:0
    Note, you aren't going to be buying Litz wire yourself. That's just the name of what the wire in the headset already is. You don't need any more wire.
    Avoid those garbage wall-plugged death sticks. A soldering iron without temperature control (a knob, buttons, lights, something) is a recipe for disaster for first-time soldering users, and a very common newbie trap. It takes soldering skill to know how to handle an unregulated soldering iron :)
    An excellent soldering iron for pro and beginners alike is the Pinecil ($40, Amazon). Soldering temperature for this job would probably be about 650f (that is: on the low side, for delicate work with small thermal mass).
    Another noob trap: avoid lead-free solder for beginning soldering. 60/40 (or 63/37, or similar) is commonly used for normal soldering work. "Rosin core" means it has flux in the center of the solder wire, which is what's needed to make the metals "accept" the solder and become "wet".
    I've not checked myself, but quite likely there are great vids on YouTube!
    Matt Falcon -
crwdns2935229:05crwdne2935229:0
Matt Falcon
crwdns2935283:005/09/15crwdne2935283:0
2 677 crwdns2915208:0crwdne2915208:0
Solder joint might look OK, but actually isn’t!
Three things I observed with my Nuraphones:
1. While the solder joint looked like it wasn’t broken and the wire appeared to be still connected to the solder blob, it actually was only held by Kevlar core inside the copper wire. The surrounding copper threads had been torn off, which was impossible to see with the naked eye, due to the fact that the blob was partially covered with copper rust AKA verdigris.Unfortunately I forgot to take a before picture, but here you can see the Kevlar and the verdigris:
https://live.staticflickr.com/65535/5344...
In other words: Insufficient contact although looking OK on visual inspection.
2. The ring shaped, capacitive FlexPCB had detached from the foam pad (the adhesive strip inbetween was smeary and gooey than sticky, I assume from aging), and thus had shifted, no longer making proper contact with the skin around the right ear. I removed the gooey, aged adhesive and carefully reattached the FlexPCB to the foam pad using several superglue areas.
Note that the foam pad ring appears to have a bigger diameter than the FlexPCB ring and the silicone cup. To me it looks as if the foam pad gets compressed in X/Y direction when inserted into the silicone cup, which makes reattaching the FlexPCB with its fixed diameter a bit cumbersome (I'm pretty sure they must have used a jig for compressing the foam pad in the factory to attach the FlexPCB). I helped myself by cutting the transparent Kapton section of the FlexPCB to turn it into an open ring.
3. The missing capacitive skin contact (either from broken solder joint or shifted FlexPCB), actually stops the two touch buttons on the ear cups from working. So even if the headphones are on and temporarily working until they fall asleep, the touch buttons don’t respond because of the faulty capacitive wear sensor.
Thank you so much for this, I followed your instructions and found the single wire to the Capacitive Flex PCB was corroded and had come off. The only hiccup I had was determining if the loose wire was coated. I couldn’t strip it no matter how I tied so concluded that it wasn’t. (I’ve done lots of wiring, but nothing at this level of tiny gauge. So thought, just tin it clean the faulty connection solder and corrosion, attach it, put it all back together, place on head and the lovely Nura lady spoke to me with a reassuring “Battery 100%, connected”!!!
I’ve yet to find that the motion sensing is functioning correctly, but either way, I have an idea what I’m doing now. It’s May, 2025, and I’ve owned them since new in 2018 or 19, so this has given them a new lease on life.
Thank you again!
Ken Kemp - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 59
crwdns2942667:0crwdne2942667:0 2,020
