identify the exact type of your ThinkPad
get the right fan assembly, in this case FRU P/N: 42W2779
disconnect power-supply
detach battery
find all five screws with the shown symbols and unscrew them
unscrew all the shown screws
These ones are tiny
On Step 3 on the top left, the screw to remove is actually the one next to the red circle not the one in the circle.
Step 3 Pic 1: The red circled screws alone are not enough! All screws at the corners must be removed, or else the bezel is still screwed onto.
remove the palm rest carefully
blow the dust away
lift the keyboard carefully
Use a spudger to detach the cable
lift the keyboad and leave it on the side
unscrew the left and right screw of the keyboard bezel and speakers
unscrew the first two screws of the shielding
carefully lift the wireless antenna cable from the cable guide
unscrew the last two screws from the keyboard bezel
carefully pull out the keyboard bezel
flip the bezel 180°
This is a really great procedure. My comment is very close to the one above.
At step 10, between the first and second bullet:
Close the screen and flip the computer over.
Remove the two screws at the backside upper edges. this will free up the keyboard bezel. (Look at the screws pictured in step 3 circled in red.)
On the left, the screw to remove is a the 5 o'clock position to the red circle.
On the right, the screw to remove is at the 2 o'clock position to the red circle.
Flip the computer back over and open it up with the screen at a 90 degree angle to the keyboard (now removed)
In this position it will be much easier to remove the keyboard bezel.
Thanks again, my wife was very happy to get her computer back in working order.
James
remove the wireless antenna cable from the cable guide of the fan assembly
unscrew the fist, tiny screw of the clip
unscrew the longer screw of the clip
remove the clip
remove the shorter screw of the second clip
remove the longer screw of the second clip
remove the clip
remove the last two screws of the fan assembly
detach the power cord with a spudger
CPU with thermal grease
other chip with termal grease
carfully lift the fan assembly
you may need to pull a little more because of the thermal grease
blow the dust away
take a spudger and remove the old thermal grease
get a paper-wiper
wrap the wiper around the spudger
get some alcohol on the wiper
clean the CPU with the wiper
clean the chip with the wiper
Ensure there is no old thermal grease left
Follow this guide to add new thermal paste to the CPU.
now place the new fan assembly
press down the CPU- and chip-connector
don't forget to plugin the power cable of the fan assembly
Can you please tell me where I can get a Lenovo Thinkpad Rseries R61 Type 8918-DEG fan because I nedd to replace my old one. (I live in South Africa)
This worked perfectly for a couple of my IBM Lenovo R61s. It was spot on except in step 3 you need to remove both screws by the red circles in order to the get inside bezel off, for the R61 anyway. Thanks for the great tutorial!
Excellent guide! It took me less than 1 hour to complete all the steps, and get my R61 up and running again! Thanks a lot
