First remove the rear case/battery cover
Remove the battery.
Remove the two T5 Torx screws.
Prise off the lower casing towards the right in the picture, taking care not to break the two tabs
Remove the two further T5 torx screws
Remove the three Phillips #00 screws.
Now carefully prise off the case all round and it will detach completely
Lift up the retainer using a plastic opening tool.
And carefully pull out the tab connector.
NOW PAUSE WITHOUT MOVING ANYTHING!
Carefully lift up the board from the left-hand side allowing it to 'hinge' on the metallic ribbon connector you have just noted and allow it to lay flat
Is this a HTC Wildfire S or Wildfire?
That's not HTC Wildfire S.
It's the previous model HTC Wildfire.
Is this wildfire a 3333 or wildfire s?
The freed connector for the screen should have unfolded
Now the screen can be pried from the outer case, but take care as you do so not to tear the metallic ribbon between the two casings
To detach the screen it can help to use a pry tool to push the screen from behind through the slot
The screen is detached and the connector can be wiggled out through the slot
Remove the old screen and connector altogether
The connector for the new screen now has to be wiggled back through the slot
Once the connecter is pushed through the slot, you should now stick the new screen into place using suitable adhesive strip
Fold down the ribbon connector from the screen and carefully fold the two casing halves together again, making sure that the two connectors are sticking out of the side
Reconnect the two connectors on the right hand side by pressing down
Reinsert the ribbon connector on the left hand side and push down the retaining catch
Clip the rear casing back on to the body
Put the bottom cover back in place and then replace all the screws
Replace battery and battery cover and all should now be well!
crwdns2935229:08crwdne2935229:0
Nice detailing of the teardown steps but the phone shown here is a regular HTC Wildfire (HTC G8) and not the latter HTC Wildfire S (HTC G13). Apparently, the orignal Wildfire has two variants (A3333 and A310e). Each variant uses a different digitizer (the touch glass panel on top of the actual LCD). If you need to buy a replacement digitizer, verify if your variant has an IC on the digitizer ribbon cable or not. On my phone, the shattered original digitizer had no IC on the ribbon and when I replaced it with one that had one, the phone wouldn’t recognize the touch inpupts.
Nice! If you wanna recycle any mobile screen you can contact LCD's Buyers
Thanks
