Repair an open seam (ladder stitch / invisible stitch)
  1. Repair an open seam (ladder stitch / invisible stitch), Secure the thread start: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Repair an open seam (ladder stitch / invisible stitch), Secure the thread start: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Repair an open seam (ladder stitch / invisible stitch), Secure the thread start: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Cut a piece of sewing thread and thread the needle. It's better to take a bit too much thread than too little.
    • Insert the needle at the edge on one side of the opening, stitching in and out along the edge. The stitch should be 1-2 mm long.
    • Leave at least 5 cm of thread hanging.
    • Stitch again at the same entry point and come out at the same exit point.
    • Repeat this a second time, so you’ve sewn the same stitch a total of three times. This secures the thread so it won’t slip out.
    • I prefer using this technique to secure the starting thread instead of a knot. A knot can easily slip through the fabric. Plus, with this seam, it would be visible.
    • I should have actually started a bit further to the right here, where the intact seam still is. In my case, it’s not a big deal, but you’ll get a cleaner seam if you secure the thread where the intact seam is.
  2. Repair an open seam (ladder stitch / invisible stitch), Ladder stitch / invisible stitch: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Repair an open seam (ladder stitch / invisible stitch), Ladder stitch / invisible stitch: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Repair an open seam (ladder stitch / invisible stitch), Ladder stitch / invisible stitch: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Push the thread end into the opening so it’s no longer visible.
    • Start with the actual seam. First stitch:
    • Stitch into the opposite edge, making sure the entry point is directly across from the exit point of the thread-securing stitch. The thread should bridge the opening in a straight line.
    • The stitch goes along the edge again and comes out 1-2 mm further.
    • Second stitch:
    • Stitch back into the first edge, directly across from the exit point of the first stitch. Again, a straight bridge forms across the opening.
  3. Repair an open seam (ladder stitch / invisible stitch): crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Repair an open seam (ladder stitch / invisible stitch): crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Repair an open seam (ladder stitch / invisible stitch): crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Continue sewing stitch by stitch in this manner until you reach the end of the opening.
    • Now you see why this technique is called "ladder stitch": the thread stretches between the two fabric edges like the rungs of a ladder.
    • Now gently pull the thread so that the two edges are drawn together and the opening closes.
    • If your opening is longer than 2-3 cm, you shouldn’t wait until the end of the seam to pull the thread. Instead, pull it every—surprise :)—2-3 cm.
  4. Repair an open seam (ladder stitch / invisible stitch), Secure the thread end: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Repair an open seam (ladder stitch / invisible stitch), Secure the thread end: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Repair an open seam (ladder stitch / invisible stitch), Secure the thread end: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The gap closes, and the thread is no longer visible. You can only see the threads of the intact seam on both sides here. As I said, I should have started sewing further to the right.
    • Now secure the thread end by sewing the same stitch three times, just like when securing the thread start.
  5. Repair an open seam (ladder stitch / invisible stitch), Sew in the thread end: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Repair an open seam (ladder stitch / invisible stitch), Sew in the thread end: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Repair an open seam (ladder stitch / invisible stitch), Sew in the thread end: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Stitch as closely as possible to the exit point and slide the needle a few centimeters through the fabric. Make sure the needle runs between the two fabric layers and doesn’t come out on the other side of the lower layer.
    • Pull the needle out, tighten the thread, and cut the thread end. Tug slightly on the fabric so the last bit of thread disappears between the fabric layers.
    • Voilà - the invisible seam!
Done! Enjoy your restored garment, pillow, sofa cover, bag, or whatever you just mended for a long time :)
crwdns2934873:0crwdne2934873:0
de en
100%
crwdns2934885:0crwdne2934885:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
Maria Parker
crwdns2935283:003/01/22crwdne2935283:0
19,074 crwdns2915208:0crwdne2915208:0
German Translators crwdns2935289:0German Translatorscrwdne2935289:0
Community
crwdns2931471:042crwdne2931471:0
crwdns2935297:01,542crwdne2935297:0
crwdns2936751:024crwdne2936751:0 9
crwdns2936753:07crwdne2936753:0 47
crwdns2936753:030crwdne2936753:0 244
crwdns2942667:0crwdne2942667:0 1,688
