Removing the Logitech MBJ58 Scroll Wheel from its Mount
  1. Removing the Logitech MBJ58 Scroll Wheel from its Mount, Top cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Hold the mouse so that the bottom is facing up.
    • Remove the single Phillips #1 screw from the bottom half of the mouse.
    باز کردن پیچ زیر موس
    h sh - crwdns2934203:0crwdne2934203:0
    There may be a sticker covering the screw hole.
    Eric Jensen - crwdns2934203:0crwdne2934203:0
  2. Removing the Logitech MBJ58 Scroll Wheel from its Mount: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Removing the Logitech MBJ58 Scroll Wheel from its Mount: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Place the mouse so that the bottom is resting against a hard surface.
    • Lift the top cover of the mouse gently, and remove it.
    جدا کردن قاب رو و زیر موس
    The cover doesn’t lift straight up on my model - once you raise the back slightly as shown, gently pull it backward (parallel to the table top, away from the cord) to disengage two plastic clips that connect the bottom to the top.
  3. Removing the Logitech MBJ58 Scroll Wheel from its Mount, Removing the Logitech MBJ58 Mouse Scroll Wheel: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Removing the Logitech MBJ58 Scroll Wheel from its Mount, Removing the Logitech MBJ58 Mouse Scroll Wheel: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Removing the Logitech MBJ58 Scroll Wheel from its Mount, Removing the Logitech MBJ58 Mouse Scroll Wheel: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate the scroll wheel on the mouse.
    • Grab the scroll wheel with your thumb and index finger.
    • Gently lift up, to remove the scroll wheel from the mouse.
    خارج کردن چرخ اسکرول موس
    Good information!
    My mouse is like new again.
    Many thanks
    Arie Dekker - crwdns2934203:0crwdne2934203:0
  4. Removing the Logitech MBJ58 Scroll Wheel from its Mount, Support Spring: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Removing the Logitech MBJ58 Scroll Wheel from its Mount, Support Spring: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the spring on the scroll wheel, and carefully remove the spring.
    نحوه قرارگیری فنر سمت راست چرخ اسکرول
  5. Removing the Logitech MBJ58 Scroll Wheel from its Mount, Attaching the New Spring: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Removing the Logitech MBJ58 Scroll Wheel from its Mount, Attaching the New Spring: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Place the replacement spring on the correct side of the wheel (shown in the images) with the prongs pointing down.
  6. Removing the Logitech MBJ58 Scroll Wheel from its Mount, Wheel Mount: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Removing the Logitech MBJ58 Scroll Wheel from its Mount, Wheel Mount: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Removing the Logitech MBJ58 Scroll Wheel from its Mount, Wheel Mount: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate the black wheel mount.
    • Note: Make sure that the spring hidden in the mount does not fall out.
    • Separate the wheel from its mount.
Conor Whatley
crwdns2935283:001/11/13crwdne2935283:0
510 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 5-14, Forte Winter 2013 crwdns2935289:0Cal Poly, Team 5-14, Forte Winter 2013crwdne2935289:0
CPSU-FORTE-W13S5G14
crwdns2935297:023crwdne2935297:0
Thank you! The photographs with good resolution and correct lighting made everything clear and comprehencible.
Антон Вакаренко - crwdns2934203:0crwdne2934203:0
Very helpful, thank you!
K.S. - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 1,824
