Removing the Apple Cinema Display M8149 Display Hinge
  1. Removing the Apple Cinema Display M8149 Display Hinge, Display Hinge: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Removing the Apple Cinema Display M8149 Display Hinge, Display Hinge: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Removing the Apple Cinema Display M8149 Display Hinge, Display Hinge: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Before starting, make sure the display is UNPLUGGED. Failure to do so can result in shock and serious injury.
    • Flip the Cinema Display so it is on its face and the feet are pointed away from you.
    • Using the PH 2 screwdriver, unscrew the three feet screws (9.52 x 4.43 mm).
    • Remove the back foot from the hinge mount by gently pulling it upwards.
  2. Removing the Apple Cinema Display M8149 Display Hinge: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Removing the Apple Cinema Display M8149 Display Hinge: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Removing the Apple Cinema Display M8149 Display Hinge: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the back plate screws (5.25 x 4.43 mm) using the PH 2 screw driver.
    • Lift the back plate off of the display.
    • Completely remove the back plate and set it aside.
  3. Removing the Apple Cinema Display M8149 Display Hinge: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Removing the Apple Cinema Display M8149 Display Hinge: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the Apple Display Connector plate screws (9.52 x 3.43 mm) with the PH 2 screwdriver.
    • Once the two screws have been removed, move the cord out of the way.
  4. Removing the Apple Cinema Display M8149 Display Hinge: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Removing the Apple Cinema Display M8149 Display Hinge: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Removing the Apple Cinema Display M8149 Display Hinge: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the hinge plate screws (5.52 x 3.43 mm) with the PH 2 screw driver.
    • Then lift out the hinge mount.
Thomas Harper
crwdns2935283:004/01/11crwdne2935283:0
268 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 10-41, Forte Spring 2011 crwdns2935289:0Cal Poly, Team 10-41, Forte Spring 2011crwdne2935289:0
CPSU-FORTE-S11S10G41
crwdns2935297:018crwdne2935297:0
in 2023 where can I get a replacement stand?
Mitch Leung - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 28
crwdns2942667:0crwdne2942667:0 8,089
