Remove the Write Protect Screw
  1. Remove the Write Protect Screw, Remove the rubber pads: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Remove the Write Protect Screw, Remove the rubber pads: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip your Chromebook Pixel over onto its back
    • Using a flat edge screwdriver, gently pull up to remove the rubber pads from the laptop to reveal the screws
  2. Remove the Write Protect Screw, Removing the bottom panel: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Remove the Write Protect Screw, Removing the bottom panel: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Remove the Write Protect Screw, Removing the bottom panel: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a small Philips screwdriver, remove the four screws under the pads
    • Using a spudger (or another flat but slightly blunt object), gently pry the laptop open
    • You may find it helpful to start with a smaller (skinnier) head and work your way up to a larger size
  3. Remove the Write Protect Screw, Pop it open: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Remove the Write Protect Screw, Pop it open: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently pull up from the front of the laptop and open it up like a clamshell
  4. Remove the Write Protect Screw, Remove the write protect screw (IF APPLICABLE): crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Remove the Write Protect Screw, Remove the write protect screw (IF APPLICABLE): crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the write protect screw
    • Remove it and you can begin flashing your BIOS!
    Do I have to flash the bios when replacing the battery?
    Clive Gorman - crwdns2934203:0crwdne2934203:0
    There is no need to flash the BIOS if all you want to do is replace the battery.
    Kevin Fessler -
    I want to install windows on to the chrome book pixel 2013 but i have concerns regarding the touch screen. Can you help? Is there any video that you have uploaded for the installation?
    Hari Krishna Bharadw Pudipeddi - crwdns2934203:0crwdne2934203:0
    How to check if screw is already removed or not? By not opening its back.
    Abdullah Ishfaq - crwdns2934203:0crwdne2934203:0
crwdns2935229:016crwdne2935229:0
Kevin Fessler
crwdns2935283:004/16/16crwdne2935283:0
1 830 crwdns2915208:0crwdne2915208:0
removing this will allow me to boot and install windows?
john Akday - crwdns2934203:0crwdne2934203:0
It will allow you to install Windows to the main hard drive and boot to it, but! As of yet, there’s no way that I’ve found to get the trackpad working in Windows with the Chromebook Pixel.
Kevin Purdy -
Acer R752TN write protect screw location?
Fredrik Løvås - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 11
crwdns2936753:07crwdne2936753:0 52
crwdns2936753:030crwdne2936753:0 263
crwdns2942667:0crwdne2942667:0 42,318
