Remove the Suction Handle and Lay Your Phone Down
crwdns2862623:0crwdne2862623:0
crwdns2942641:0crwdne2942641:0
  1. Remove the Suction Handle and Lay Your Phone Down, Safety precautions: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Remove the Suction Handle and Lay Your Phone Down, Safety precautions: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Let your Pixel's battery drain below 25% before starting this repair. A charged lithium‑ion battery may catch fire if damaged.
    • Unplug all cables and completely power down your phone.
  2. Remove the Suction Handle and Lay Your Phone Down, Remove the SIM card tray: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Remove the Suction Handle and Lay Your Phone Down, Remove the SIM card tray: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Remove the Suction Handle and Lay Your Phone Down, Remove the SIM card tray: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Firmly press a SIM eject tool, bit, or straightened paper clip into the SIM card tray hole on the bottom edge of your phone until the tray ejects.
    • A small mic hole is next to the SIM tray—don't confuse the two!
    • Remove the SIM card tray.
  3. Remove the Suction Handle and Lay Your Phone Down, Heat the rear cover: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Remove the Suction Handle and Lay Your Phone Down, Heat the rear cover: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Remove the Suction Handle and Lay Your Phone Down, Heat the rear cover: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Adhesive secures the rear cover to the frame. Heating the cover softens the adhesive, making it easier to separate.
    • Use a hair dryer to heat the entire rear cover.
    • Only heat your phone so it's just hot to the touch. Extreme heat can damage the rear cover, screen, or battery.
  4. Remove the Suction Handle and Lay Your Phone Down, Apply a suction handle: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Remove the Suction Handle and Lay Your Phone Down, Apply a suction handle: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Apply a suction handle near the center of the rear cover's right edge, as close to the edge as possible.
  5. Remove the Suction Handle and Lay Your Phone Down, Insert an opening pick: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Remove the Suction Handle and Lay Your Phone Down, Insert an opening pick: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Remove the Suction Handle and Lay Your Phone Down, Insert an opening pick: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull up on the suction handle with strong, steady force until a gap forms between the cover and frame.
    • Insert the tip of an opening pick into the gap.
  6. Remove the Suction Handle and Lay Your Phone Down, Adhesive information: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Remove the Suction Handle and Lay Your Phone Down, Adhesive information: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Remove the Suction Handle and Lay Your Phone Down, Adhesive information: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The rear cover is secured with adhesive around the perimeter of the frame and near the cameras. Use this picture as a reference while you separate the adhesive.
    • When separating the left and right edge adhesive, don't insert your pick more than 3 mm to avoid damaging the wireless charging coil and its graphite film.
  7. Remove the Suction Handle and Lay Your Phone Down, Separate the rear cover adhesive: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Remove the Suction Handle and Lay Your Phone Down, Separate the rear cover adhesive: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Remove the Suction Handle and Lay Your Phone Down, Separate the rear cover adhesive: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • If you ever have trouble separating the adhesive, apply more heat and try again.
    • Slide the opening pick up the right edge, around the top right corner, and along the top edge to separate the adhesive securing the rear cover.
  8. Remove the Suction Handle and Lay Your Phone Down: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Remove the Suction Handle and Lay Your Phone Down: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Remove the Suction Handle and Lay Your Phone Down: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert an opening pick in the initial gap you created near the center of the rear cover's right edge.
    • Slide the opening pick down the right edge, along the bottom edge, and up the left edge to separate the adhesive securing the cover.
  9. Remove the Suction Handle and Lay Your Phone Down, Separate the camera bezel adhesive: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Remove the Suction Handle and Lay Your Phone Down, Separate the camera bezel adhesive: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Remove the Suction Handle and Lay Your Phone Down, Separate the camera bezel adhesive: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the flat edge of an opening pick under the top of the rear cover's left edge, near the camera bezel.
    • Twist the pick and apply constant pressure to separate the adhesive around the camera bezel.
  10. Remove the Suction Handle and Lay Your Phone Down, Remove the rear cover: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Remove the Suction Handle and Lay Your Phone Down, Remove the rear cover: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the rear cover.
    • If you feel resistance, go back around the perimeter of the cover and use a pick to separate any remaining adhesive.
  11. Remove the Suction Handle and Lay Your Phone Down, Remove the camera bezel: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Remove the Suction Handle and Lay Your Phone Down, Remove the camera bezel: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Remove the Suction Handle and Lay Your Phone Down, Remove the camera bezel: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • If the camera bezel detached from the rear cover and stayed stuck to your phone, follow this step to remove it. Otherwise, skip this step.
    • Slide an opening pick under the camera bezel and pry up to remove it.
    • Only insert the pick a few millimeters under the bezel, or you risk damaging the cameras.
    • If you're having trouble, lightly heat the camera bezel.
  12. Remove the Suction Handle and Lay Your Phone Down, Remove the wireless charging assembly screws: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Remove the Suction Handle and Lay Your Phone Down, Remove the wireless charging assembly screws: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    Magnetic Project Mat
    $19.95
    • Use a Torx Plus 3IP screwdriver to remove the 16 screws securing the wireless charging assembly:
    • Thirteen 5.0 mm‑long screws
    • Three 2.2 mm‑long screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your phone.
  13. Remove the Suction Handle and Lay Your Phone Down, Unclip the wireless charging assembly: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Remove the Suction Handle and Lay Your Phone Down, Unclip the wireless charging assembly: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Remove the Suction Handle and Lay Your Phone Down, Unclip the wireless charging assembly: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
  14. Remove the Suction Handle and Lay Your Phone Down, Remove the wireless charging assembly: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Remove the Suction Handle and Lay Your Phone Down, Remove the wireless charging assembly: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the wireless charging assembly.
  15. Remove the Suction Handle and Lay Your Phone Down, Remove the connector cover screw: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Remove the Suction Handle and Lay Your Phone Down, Remove the connector cover screw: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Be careful not to damage the battery with your tools while disconnecting it.
    • Use a Torx Plus 3IP screwdriver to remove the 1.7 mm‑long screw securing the battery connector cover.
  16. Remove the Suction Handle and Lay Your Phone Down, Remove the battery connector cover: crwdns2935265:016crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Remove the Suction Handle and Lay Your Phone Down, Remove the battery connector cover: crwdns2935265:016crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Remove the Suction Handle and Lay Your Phone Down, Remove the battery connector cover: crwdns2935265:016crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use tweezers to lift and remove the battery connector cover.
  17. Remove the Suction Handle and Lay Your Phone Down, Disconnect the battery: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Remove the Suction Handle and Lay Your Phone Down, Disconnect the battery: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to pry up and disconnect the battery cable press connector.
  18. Remove the Suction Handle and Lay Your Phone Down, Remove the logic board screws: crwdns2935265:018crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Remove the Suction Handle and Lay Your Phone Down, Remove the logic board screws: crwdns2935265:018crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Remove the Suction Handle and Lay Your Phone Down, Remove the logic board screws: crwdns2935265:018crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a 3IP Torx Plus screwdriver to remove the two 2.8 mm‑long screws securing the logic board.
  19. Remove the Suction Handle and Lay Your Phone Down, Lift the logic board: crwdns2935265:019crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Remove the Suction Handle and Lay Your Phone Down, Lift the logic board: crwdns2935265:019crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Remove the Suction Handle and Lay Your Phone Down, Lift the logic board: crwdns2935265:019crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Be careful not to smudge the cameras when handling the logic board.
    • Before trying to remove the logic board, double‑check that you removed the SIM card tray.
    • Insert the point of a spudger under the screw hole near the cameras and lift the board until you can grip it with your fingers.
  20. Remove the Suction Handle and Lay Your Phone Down, Free the bottom edge of the logic board: crwdns2935265:020crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Remove the Suction Handle and Lay Your Phone Down, Free the bottom edge of the logic board: crwdns2935265:020crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Remove the Suction Handle and Lay Your Phone Down, Free the bottom edge of the logic board: crwdns2935265:020crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Don't try to fully remove the logic board yet, as it's still connected to the frame by the screen cable.
    • Grip the skinny section of the board with your fingers and lift until the clip near the bottom edge of the battery releases.
    • Pull the top edge of the board to the right of the frame until the charge port slides fully out of its recess.
  21. Remove the Suction Handle and Lay Your Phone Down, Lay the logic board down: crwdns2935265:021crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Remove the Suction Handle and Lay Your Phone Down, Lay the logic board down: crwdns2935265:021crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Remove the Suction Handle and Lay Your Phone Down, Lay the logic board down: crwdns2935265:021crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The logic board may fall out of place during this step. Hold it steady, but don't grip any of the camera lenses or connectors.
    • Apply a suction handle to the screen and use it to prop up your phone.
    • Gently lay the logic board down flat against your work surface, being careful not to strain the screen cable.
  22. Remove the Suction Handle and Lay Your Phone Down, Remove the logic board connector cover: crwdns2935265:022crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Remove the Suction Handle and Lay Your Phone Down, Remove the logic board connector cover: crwdns2935265:022crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Torx Plus 3IP screwdriver to remove the 1.7 mm‑long screw securing the screen cable cover.
  23. Remove the Suction Handle and Lay Your Phone Down, Remove the connector cover: crwdns2935265:023crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Remove the Suction Handle and Lay Your Phone Down, Remove the connector cover: crwdns2935265:023crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Remove the Suction Handle and Lay Your Phone Down, Remove the connector cover: crwdns2935265:023crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use tweezers to lift and remove the screen cable cover.
  24. Remove the Suction Handle and Lay Your Phone Down, Disconnect the logic board: crwdns2935265:024crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Remove the Suction Handle and Lay Your Phone Down, Disconnect the logic board: crwdns2935265:024crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the flat end of a spudger to pry up and disconnect the screen cable press connector.
  25. Remove the Suction Handle and Lay Your Phone Down, Remove the logic board: crwdns2935265:025crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Remove the Suction Handle and Lay Your Phone Down, Remove the logic board: crwdns2935265:025crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the logic board away from the frame and remove it.
  26. Remove the Suction Handle and Lay Your Phone Down, Lay your phone down: crwdns2935265:026crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Remove the Suction Handle and Lay Your Phone Down, Lay your phone down: crwdns2935265:026crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the suction handle from the screen and lay your phone down.
Spencer Day
crwdns2935283:009/14/22crwdne2935283:0
119.619 crwdns2915208:0crwdne2915208:0
crwdns2935297:0838crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021.995crwdne2935297:0
crwdns2936753:030crwdne2936753:0 2
crwdns2942667:0crwdne2942667:0 40
