Remove IBM WorkPad c3 Battery
crwdns2869540:0crwdne2869540:0: 5.2K
3
18
92
5,162
crwdns2959984:0crwdne2959984:0: 1
crwdns2959972:01crwdne2959972:0
crwdns2959986:0crwdne2959986:0: 1
crwdns2959980:01crwdne2959980:0
crwdns2955944:0crwdne2955944:0: crwdns2931287:05crwdne2931287:0
crwdns2955970:0crwdne2955970:0: crwdns2937799:0crwdne2937799:0
If your battery is not working you can remove it and replace it following the step by step process. The battery can easily just pop out following simple steps
    1. Remove IBM WorkPad c3 Battery, Back Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Remove IBM WorkPad c3 Battery, Back Case: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Turn the device over so that the screen is facing down.
      • In the next step the device will be heated, so the screen must be turned over to prevent heat damage to the LCD/Digitizer.
    2. Remove IBM WorkPad c3 Battery: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Using a hair dryer, slowly heat the edges of the WorkPad.
      • Spend at least one minute heating each side of the device. This will melt the glue holding the case together, and allow it to be removed.
      • Be sure not to touch the device directly after heating as it will be extremely hot. Use a towel or oven mitt to grab it.
    3. Remove IBM WorkPad c3 Battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Remove IBM WorkPad c3 Battery: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use a plastic opening tool to pry the back case from the WorkPad.
      • If the rear cover is not coming off very easily, you probably need to reheat the case in order to sufficiently melt the glue.
    1. Remove IBM WorkPad c3 Battery, Battery: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the yellow tape that is covering the battery connector
    2. Remove IBM WorkPad c3 Battery: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Using the tweezers, carefully disconnect the battery cable from the port
    3. Remove IBM WorkPad c3 Battery: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Remove IBM WorkPad c3 Battery: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Using the plastic opening tools, lift the battery out of the case
      • The battery is secured with adhesive and it will take some effort to remove
Emily Falkenstein
crwdns2935283:010/05/10crwdne2935283:0
75 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 21-35, Regan Fall 2010 crwdns2935289:0Cal Poly, Team 21-35, Regan Fall 2010crwdne2935289:0
CPSU-REGAN-F10S21G35
crwdns2936753:07crwdne2936753:0 18
crwdns2936753:030crwdne2936753:0 92
crwdns2959996:0crwdne2959996:0 5,162
