If you forgot your password, or you want to delete all data, or you have problem with power on the tablet...
crwdns2936621:0crwdne2936621:0
- Make Surface turned off and plugged in.
- Insert the USB recovery drive into the USB port.
- Press and hold the Volume Down button, press the Power button in a short time.
- When the Surface logo appears, release the Volume button.
- Select the language and keyboard layout.
Now you are in the Advanced Startup Options menu. You can choose from:
- Refresh your PC
- Reset your PC
...or from Advanced options menu:
- Start-up repair
- Command prompt
I tried downloading recovery image but some error while extracting it into the usb. Please help.
crwdns2935229:08crwdne2935229:0
Hello.my surface rt is not working properly.The windows is on and off.What should i do?
Hello.My surface rt is not working properly.
The windows display is on and off. What should i do to prenvent it?
Hello!
RT is not working properly ! I have Surface RT arm and no eny possibility to come in to uefi even I press upp vol. and press on. The tablet will no start and will not to be able on for around 3 \4 minutes. The USB with the windows is it in but when I tray to start with vol down and press on not working like the video shwoing. :(
Where do I get the USB from?
Soto Jaime - crwdns2934203:0crwdne2934203:0
