Rear Turn Signal Bulb Replacement
  1. Rear Turn Signal Bulb Replacement, Rear Turn Signal Bulb: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Rear Turn Signal Bulb Replacement, Rear Turn Signal Bulb: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Rear Turn Signal Bulb Replacement, Rear Turn Signal Bulb: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The stop/turn signal bulb is located in the outer rear lamp unit that is secured at the rear of each quarter panel
    • Open the tail gate and locate the two fasteners holding the light assembly to the quarter panel.
    • Locate the notches in the outer ring of the fasteners. Those are to facilitate the use of a screw driver to remove the fasteners.
  2. Rear Turn Signal Bulb Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Rear Turn Signal Bulb Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Rear Turn Signal Bulb Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert a flathead screwdriver or similar tool and pry out the center of the fastener
    • A pair of pliers, or similar tool, can be used to get a better hold on the fastener
    • Completely remove the fastener
  3. Rear Turn Signal Bulb Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Rear Turn Signal Bulb Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Rear Turn Signal Bulb Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Proceed the same way with the bottom fastener. Pry out the center.
    • Use pliers or similar tool to pull the fastener
    • Completely remove fastener
  4. Rear Turn Signal Bulb Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Rear Turn Signal Bulb Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Rear Turn Signal Bulb Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The tail light assembly is still held in place by two guide pegs. Gently pull the complete assembly toward the rear of the vehicle to unseat the pegs.
    • Fully remove the tail light assembly
    • The assembly can rest on the top of the rear bumper. The Stop/Turn signal bulb is the larger one of the two bulb fixtures.
  5. Rear Turn Signal Bulb Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Rear Turn Signal Bulb Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Rear Turn Signal Bulb Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the bulb socket by turning it about 1/4 turn in a counter clockwise direction
    • Remove the socket from the light assembly
    • Remove the bulb from the socket by pulling it straight out.
  6. Rear Turn Signal Bulb Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Replace the burned out bulb with a new type 3057 dual filament bulb
oldturkey03
crwdns2935283:009/29/10crwdne2935283:0
821.717 crwdns2915208:0crwdne2915208:0
crwdns2935297:0122crwdne2935297:0
crwdns2947412:05crwdne2947412:0
What if the trunk don’t open is it possible to change a blinker bulb ?
Shellie Gill - crwdns2934203:0crwdne2934203:0
No. Step 1 picture 2 can't be accessed if it does not open
oldturkey03 -
I'm a female and I will give it a try.
janice_montalto - crwdns2934203:0crwdne2934203:0
1*Onde posso ter informações de como trocar a lampada do farol dianteiro ?
2* Meu carro entrou água e agora as setas fficam piscando, algo q posso resolver ?
Tharles - crwdns2934203:0crwdne2934203:0
3* comprei um .módulo de tração que fica embaixo do banco do motorista , mais ao colocar o carro não reconheceu, com9 resolver?
crwdns2936753:030crwdne2936753:0 100
crwdns2942667:0crwdne2942667:0 19,926
