Razer Kraken Ultimate Power/Connection Cable Replacement
  1. Razer Kraken Ultimate Power/Connection Cable Replacement, Ear Pads: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Razer Kraken Ultimate Power/Connection Cable Replacement, Ear Pads: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Razer Kraken Ultimate Power/Connection Cable Replacement, Ear Pads: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Grab the ear piece from one of the sides and lightly pull it outwards.
    • Ideally, do not pull the ear piece directly away from the speaker; it may damage the piece.
  2. Razer Kraken Ultimate Power/Connection Cable Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Razer Kraken Ultimate Power/Connection Cable Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Once you have taken off one side, you can then remove the whole piece by slowly prying the pad away from the headphones.
  3. Razer Kraken Ultimate Power/Connection Cable Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Razer Kraken Ultimate Power/Connection Cable Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Repeat steps on the other side.
  4. Razer Kraken Ultimate Power/Connection Cable Replacement, Speaker: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Razer Kraken Ultimate Power/Connection Cable Replacement, Speaker: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Razer Kraken Ultimate Power/Connection Cable Replacement, Speaker: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the four 10 mm Phillips #00 screws securing the right speaker.
    • Be sure the device is unplugged before attempting to remove any of the screws.
  5. Razer Kraken Ultimate Power/Connection Cable Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Razer Kraken Ultimate Power/Connection Cable Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 10 mm Phillips #00 screws securing the left speaker.
    • Note that one of the screws is hidden behind the product information sticker. Use your screw driver to punch a hole in the sticker.
  6. Razer Kraken Ultimate Power/Connection Cable Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Razer Kraken Ultimate Power/Connection Cable Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • To fully detach the speakers cut the wires as close as possible to the connection point, leaving plenty of room to solder the new speaker on.
  7. Razer Kraken Ultimate Power/Connection Cable Replacement, Microphone: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Razer Kraken Ultimate Power/Connection Cable Replacement, Microphone: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Razer Kraken Ultimate Power/Connection Cable Replacement, Microphone: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the two 10 mm Phillips #00 screws securing the microphone.
  8. Razer Kraken Ultimate Power/Connection Cable Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently pry the bottom connection away from the casing with the iFixit opening tool.
  9. Razer Kraken Ultimate Power/Connection Cable Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Razer Kraken Ultimate Power/Connection Cable Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the microphone down and out of the casing.
  10. Razer Kraken Ultimate Power/Connection Cable Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Open up the casing the microphone retracks into.
    • Cut the cable as close to the microphone as possible, leaving behind enough to solder the new microphone to.
    • The casing the microphone if removed correctly in the previous step is easily opened by hand
  11. Razer Kraken Ultimate Power/Connection Cable Replacement, Motherboard: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 6 mm Phillips #00 screws that secure the motherboard.
    • One of the screws is located near where many cables connect; take care not to disconnect them.
  12. Razer Kraken Ultimate Power/Connection Cable Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently lift the motherboard from the case, with care not to damage any of the connected cables.
  13. Razer Kraken Ultimate Power/Connection Cable Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Razer Kraken Ultimate Power/Connection Cable Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Razer Kraken Ultimate Power/Connection Cable Replacement: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • There are two ribbon cables that must be removed.
    • To remove these cables pull the gray connecting piece out about 0.5mm to unlock the cable.
    • Then simply pull the cable out.
  14. Razer Kraken Ultimate Power/Connection Cable Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Repeat previous step with second cable.
  15. Razer Kraken Ultimate Power/Connection Cable Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once screws are removed and ribbon cables are disconnected, lift the motherboard out.
    • Some wire connections are secured to the motherboard with hot glue. To completely remove the motherboard all wires must be disconnected. Removing such connections goes beyond the scope of this guide.
  16. Razer Kraken Ultimate Power/Connection Cable Replacement, Power/Connection Cable: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Razer Kraken Ultimate Power/Connection Cable Replacement, Power/Connection Cable: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • After unscrewing the motherboard, gently pull it away from the headset and turn it over.
  17. Razer Kraken Ultimate Power/Connection Cable Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Grab your tweezers and focus your attention on the white connector. Pictured on the right of the motherboard. This is the cable.
  18. Razer Kraken Ultimate Power/Connection Cable Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Razer Kraken Ultimate Power/Connection Cable Replacement: crwdns2935265:018crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Razer Kraken Ultimate Power/Connection Cable Replacement: crwdns2935265:018crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Press in on the two tabs on the sides of the box, while using your tweezers to push the cable out of its port, disconnecting it.
    • The two tabs are indentations on the sides of the top face of the box.
Lincoln Karle
crwdns2935283:010/26/22crwdne2935283:0
159 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 1-4, Petersen Fall 2022 crwdns2935289:0UMass Dartmouth, Team 1-4, Petersen Fall 2022crwdne2935289:0
UMASSD-PETERSEN-F22S1G4
crwdns2935297:011crwdne2935297:0
crwdns2947412:05crwdne2947412:0
where do i get the replacement cable?
BE YT - crwdns2934203:0crwdne2934203:0
Yes, I also want to know where to get the cable from.
Uwe Keim - crwdns2934203:0crwdne2934203:0
I know that Kraken line that have USB connection, have two types. Plug (as described on this guide) and 5-pin Welded wire.
Anyone knows what Kraken models have the Plug wire? and if the Kraken V2 7.1 have the same kind of wire of this guide?
Thank you!
Diego Mayoral Umbelino - crwdns2934203:0crwdne2934203:0
I want to know what that little white box is called. My headphones broke at the join on the ear. So I’ve cut the worn wire & made the wire shorter, I bodge jobbed the connector and it works for a week but I need the proper connector…. my standard white connector is too big. (I think JST brand)
Any ideas?
J4rming - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 52
crwdns2936753:030crwdne2936753:0 198
crwdns2942667:0crwdne2942667:0 7,982
