If your Razer Kraken Ultimate microphone is not properly picking up audio- sound is coming through distorted or it is not picking it up at all.
The headset picks up audio through a retractable microphone. A faulty microphone would cause the problems with picking up audio.
In Step 4 will require wire cutting and soldering to remove and reattach the microphone.
Grab the ear piece from one of the sides and lightly pull it outwards.
Once you have taken off one side, you can then remove the whole piece by slowly prying the pad away from the headphones.
Remove the four 10 mm Phillips #00 screws securing the right speaker.
Remove the 10 mm Phillips #00 screws securing the left speaker.
Note that one of the screws is hidden behind the product information sticker. Use your screw driver to punch a hole in the sticker.
To fully detach the speakers cut the wires as close as possible to the connection point, leaving plenty of room to solder the new speaker on.
Remove the two 10 mm Phillips #00 screws securing the microphone.
Gently pry the bottom connection away from the casing with the iFixit opening tool.
Pull the microphone down and out of the casing.
Open up the casing the microphone retracks into.
Cut the cable as close to the microphone as possible, leaving behind enough to solder the new microphone to.
