Use this guide to replace your bumper on your Razer Kishi.
Both controller sides of the Razer Kishi are almost identical in construction. The bumper replacement is similar on both sides, therefore we will only show the right side in this guide.
For the right side, remove the five Y0 screws securing the right side of the controller.
Four 9.2 mm screws
One 7.2 mm screw
If you wish to open the left side, remove the five Y0 screws securing the left side of the controller.
Four 9.2 mm screws
One 7.2 mm screw
Insert an opening pick in the seam between the top and bottom case, at the bottom left corner of the controller.
With the pick still in the seam, slide it along the bottom edge to the bottom right corner to loosen the plastic clips.
Slide the opening pick along the right edge to loosen the plastic clips.
Slide the opening pick along the top edge to loosen the remaining plastic clips.
Carefully lift the top side and unfold it to the right, like a book.
Using the pointed end of a spudger, push the grey tabs on the interconnect socket away from the socket, parallel to the interconnect cable, to release the cable.
Pull the cable out of the socket.
Use a Phillips #0 screwdriver to remove the two 4.4 mm-long screws securing the trigger board.
Phillips #00 on mine.
Model no. RZ06-0290also listed: GV190
This step is not essential and risks misaligning the rotary knobs from their tracks as well as losing or contaminating the lubricant. You can leave the breakout board attached to the trigger and remove them together. When the trigger screws are out, lift the whole assembly together, being very careful to lift it straight out to avoid bending the jumper pins.
Remove the breakout board by lifting it straight up, away from the controller.
When reassembling this piece, ensure that the breakout board's rotating peg is aligned with the neutral position of the joystick. To do this on the left trigger:
1. Flip the breakout board over so that the rotating peg is facing you and position it such that the 3 jumper pins are in the top right (and the text is right-side-up.2. Carefully rotate the peg until it faces North-East, at just about a 45 degree angle from the horizontal. Move it in whatever direction requires the shortest travel to arrive at this point. Be wary of the lubricant which coats this part and try not to remove much.
On the right trigger, this process is the same but mirrored. Align with pins in top left and point peg to the North-West at 45 degrees.
Do you sell R2 button, mine is broken. If so kindly WhatsApp my number 0717709004
Use a Phillips #0 screwdriver to remove the two 7.0 mm-long screws securing the trigger.
These are #00 screws on mine
These screws have a very shallow angle for the inner Phillips drive, making them feel very easy to strip. For these, a Phillips #1 actually provided the most positive fit. Test a few tips just to be sure.
Remove the shoulder trigger.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use a pair of tweezers to remove the metal pin which holds the bumper in its place.
Use your fingers to remove the bumper.
I can't remove the left shell of the controller. It seems to be either glued down or won't snap off. I'm worried that I would break the shell or even worse, the motherboard inside. Please help because this has been broken since December of last year and I have the tools to fix it and don't want to spend money to buy a new one.
Where did you buy the spare part you want to replace?
ZettoBoi -
Saved me! Was able to get the right trigger to reattach with the high res images!
Hellooo
Unfortunately the trigger on the right is broken for me.
Can anybody say me where i can buy this spare part?
Thanks ☺️
