Razer DeathAdder V3 Pro USB-C Port Replacement
  1. Razer DeathAdder V3 Pro USB-C Port Replacement, Scroll Wheel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Razer DeathAdder V3 Pro USB-C Port Replacement, Scroll Wheel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Razer DeathAdder V3 Pro USB-C Port Replacement, Scroll Wheel: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a pry tool or fingernail to carefully remove the large foot on the lower end of the mouse.
    • Remove the three 7 mm screws using a Torx T6 screwdriver.
  2. Razer DeathAdder V3 Pro USB-C Port Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Razer DeathAdder V3 Pro USB-C Port Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • BEFORE YOU OPEN THE MOUSE: Be careful at this point. Both shells are connected with a cable in the front of the mouse.
    • Insert a spudger into the seam between the top and bottom shells.
    • Gently work around the edges unclipping the internal latches.
    • Slowly lift the top shell but do not remove it yet; the cables are still attached to the circuit board.
    • Carefully pull the shells apart to unplug the cable in the front.
  3. Razer DeathAdder V3 Pro USB-C Port Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Razer DeathAdder V3 Pro USB-C Port Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a small pry tool or your fingers, gently pop the scroll wheel up and out of its housing
  4. Razer DeathAdder V3 Pro USB-C Port Replacement, USB-C Port: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a T6 Torx screwdriver to remove the 5mm screws from the circuit board.
    • Unplug the battery from its connection on the right.
    • Be careful not to break the two clips that hold the PCB at the front of the mouse.
    • Remove the circuit board from the mouse.
  5. Razer DeathAdder V3 Pro USB-C Port Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Always solder in a well ventilated area.
    • Apply solder to the four anchor points on the back corners and side of the USB-C port.
    • Once the solder has melted, use tweezers to remove the USB-C port.
    • Use a solder sucker to clean the area.
  6. Razer DeathAdder V3 Pro USB-C Port Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Apply flux, then apply solder to one anchor point to help line up the new USB-C port.
    • Once the USB-C port is aligned, apply flux to the other three anchor points and solder them.
Nicholas
crwdns2935283:009/24/25crwdne2935283:0
453 crwdns2915208:0crwdne2915208:0
Texas Tech, Team 2-5, Johansen Fall 2025 crwdns2935289:0Texas Tech, Team 2-5, Johansen Fall 2025crwdne2935289:0
TTU-JOHANSEN-F25S2G5
crwdns2936753:030crwdne2936753:0 44
crwdns2942667:0crwdne2942667:0 221
