Razer DeathAdder V3 Pro Encoder Replacement
    1. Razer DeathAdder V3 Pro Encoder Replacement, Scroll Wheel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Razer DeathAdder V3 Pro Encoder Replacement, Scroll Wheel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Razer DeathAdder V3 Pro Encoder Replacement, Scroll Wheel: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Use a pry tool or fingernail to carefully remove the large foot on the lower end of the mouse.
      • Remove the three 7 mm screws using a Torx T6 screwdriver.
    2. Razer DeathAdder V3 Pro Encoder Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Razer DeathAdder V3 Pro Encoder Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • BEFORE YOU OPEN THE MOUSE: Be careful at this point. Both shells are connected with a cable in the front of the mouse.
      • Insert a spudger into the seam between the top and bottom shells.
      • Gently work around the edges unclipping the internal latches.
      • Slowly lift the top shell but do not remove it yet; the cables are still attached to the circuit board.
      • Carefully pull the shells apart to unplug the cable in the front.
    3. Razer DeathAdder V3 Pro Encoder Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Razer DeathAdder V3 Pro Encoder Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Using a small pry tool or your fingers, gently pop the scroll wheel up and out of its housing
    1. Razer DeathAdder V3 Pro Encoder Replacement, Encoder: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use a T6 Torx screwdriver to remove the 5mm screws securing the circuit board.
      • Unplug the battery from its connection on the right side.
      • Be careful not to break the two clips that hold the PCB at the front of the mouse.
    2. Razer DeathAdder V3 Pro Encoder Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • At the front of the PCB next to the encoder, remove the switch held in place by clips by gently pulling it free.
    3. Razer DeathAdder V3 Pro Encoder Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Razer DeathAdder V3 Pro Encoder Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Wear eye protection.
      • Take care not to damage the PCB or any other components.
      • Use a pair of flush cutters to cut the legs of the encoder.
      • Desolder the legs of the 15 mm encoder on the underside of the PCB.
      • Remove the encoder.
      • Always solder in a well ventilated area.
      • Use a solder sucker to remove any excess solder.
    4. Razer DeathAdder V3 Pro Encoder Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Press the new 15 mm encoder into place
      • If the encoder does not fit properly, clean the old solder more thoroughly.
      • Solder the new 15 mm encoder into place.
Nicholas
crwdns2935283:009/24/25crwdne2935283:0
453 crwdns2915208:0crwdne2915208:0
Texas Tech, Team 2-5, Johansen Fall 2025 crwdns2935289:0Texas Tech, Team 2-5, Johansen Fall 2025crwdne2935289:0
TTU-JOHANSEN-F25S2G5
crwdns2936751:024crwdne2936751:0 9
crwdns2936753:07crwdne2936753:0 58
crwdns2936753:030crwdne2936753:0 255
crwdns2942667:0crwdne2942667:0 1,612
