Razer Blade Stealth 2017 Battery Replacement
  1. Razer Blade Stealth 2017 Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Razer Blade Stealth 2017 Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Before you begin, be sure to turn off your laptop and discharge the battery down to 25%.
    • Use a Torx T5 screwdriver to remove the eight, 3mm screws on the bottom cover of the laptop.
    • Whenever you remove screws from the device, remember to save and label them.
  2. Razer Blade Stealth 2017 Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the bottom cover of the laptop by sliding it away from the hinge.
    • Do not force the cover up!
  3. Razer Blade Stealth 2017 Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Razer Blade Stealth 2017 Battery Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your fingernail to pry up and disconnect the battery from the motherboard.
  4. Razer Blade Stealth 2017 Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #00 screwdriver to remove the six, 5mm screws securing the battery.
    Do you have to remove the battery before swapping the wifi card? Is disconnecting the power not enough?
    Charles Tsai - crwdns2934203:0crwdne2934203:0
    Hi Charles,
    If you’re swapping the Wi-Fi card, you don’t need to remove the battery. Disconnecting it will suffice.
    Arthur Shi -
    Are two of these screws shorter than the other four? And if so, where do the two shorter screws go?
    James Spinella - crwdns2934203:0crwdne2934203:0
    Looks like the two shorter screws go where the trackpad is!
  5. Razer Blade Stealth 2017 Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Razer Blade Stealth 2017 Battery Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove any tape attached to the battery.
    • Use the plastic spudger to pry out the battery.
    After removing the 6 screws securing the battery, mine does not come out easily. There is resistance, and I don't wanna forcefully pull it out. Is it supposed to be easy to pick up and take out or is there some sort of tape holding it down from the bottom?
    kairos - crwdns2934203:0crwdne2934203:0
For optimal performance, after completing this guide, calibrate your newly installed battery.
crwdns2935229:016crwdne2935229:0
Ethan Schlocker
crwdns2935283:010/10/19crwdne2935283:0
353 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S11-G3, Regan Fall 2019 crwdns2935289:0Cal Poly, Team S11-G3, Regan Fall 2019crwdne2935289:0
CPSU-REGAN-F19S11G3
ive done everything correctly and laptop boots up but now I have no battery percentage information. any solutions on how to fix?
fdf - crwdns2934203:0crwdne2934203:0
Where did you get the replacement battery? The replacement we purchased for two Razer units about a year ago worked fine, but a replacement battery purchased online about a month and a half ago from Amazon is showing the same issue. Essentially, it's not detected by the operating system at all, or only very rarely. Looks like a bad batch of batteries from wherever these sellers are getting their supply.
DST - crwdns2934203:0crwdne2934203:0
The laptop powers on but when plugged in it starts then stops charging
Boogie - crwdns2934203:0crwdne2934203:0
Hey Boogie!
I am also having same issue, have you manage to solve it?
Andrea Torrico -
crwdns2936753:030crwdne2936753:0 52
crwdns2942667:0crwdne2942667:0 18,245
