Over time, lithium-ion batteries inevitably degrade, dramatically reducing their lifespan. The higher operating temperatures in gaming laptops speeds up their degradation; if you've been using your Razer Blade RZ09-0130 2015 for more than a couple years, and the battery life is either very short, or it can't even run while unplugged, it's definitely time for a replacement.
Before beginning these guide, make sure that the system is shut down, unplugged, and that there is no static build up on your person.
If you find your battery is swollen, take extreme caution in removal, and dispose of your battery through the proper channels.
Use a Torx T5 screwdriver to remove the ten 3 mm screws along the edge of the back panel.
Remove the back panel from the laptop by sliding it away from the hinge.
Detach the battery's ribbon cable from the motherboard.
Use a Phillips #0 screwdriver to remove the six 3 mm screws securing the battery.
Lift the battery up and out.
