Razer Blade Pro 17 2019 Battery Replacement
  1. Razer Blade Pro 17 2019 Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Razer Blade Pro 17 2019 Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unplug the laptop.
    • Press and hold the power button to shut down the laptop.
  2. Razer Blade Pro 17 2019 Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Razer Blade Pro 17 2019 Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Razer Blade Pro 17 2019 Battery Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the 12 screws that secure the lower case with a T5 Torx screwdriver.
  3. Razer Blade Pro 17 2019 Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Razer Blade Pro 17 2019 Battery Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Razer Blade Pro 17 2019 Battery Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the opening picks into the gap between the back plate and the body of the laptop and pry around the perimeter until the lower case releases.
    • It is easier to use the gap at the ethernet port.
    • Lift up and remove the lower case.
    • Be careful not to place anything on the back to avoid scratching any components.
  4. Razer Blade Pro 17 2019 Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Razer Blade Pro 17 2019 Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Razer Blade Pro 17 2019 Battery Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the black sticker on the fan assembly.
  5. Razer Blade Pro 17 2019 Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Razer Blade Pro 17 2019 Battery Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your fingernails to gently "walk" the battery connector directly out of its port.
    • Do not pull directly on the wires, as depicted in the photo.
  6. Razer Blade Pro 17 2019 Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Razer Blade Pro 17 2019 Battery Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your fingernails or a spudger to gently lever the fan connector directly out of its socket.
    • Do not pull directly on the wires, as show in the photos.
  7. Razer Blade Pro 17 2019 Battery Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Razer Blade Pro 17 2019 Battery Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Razer Blade Pro 17 2019 Battery Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Phillips #1 screwdriver to remove the 10 screws that secure the battery and fan assembly.
  8. Razer Blade Pro 17 2019 Battery Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Razer Blade Pro 17 2019 Battery Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Razer Blade Pro 17 2019 Battery Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the fan assembly and battery out of the chassis.
For optimal performance, calibrate your newly installed battery after completing this guide.
Nate
crwdns2935283:004/15/24crwdne2935283:0
175 crwdns2915208:0crwdne2915208:0
UC Davis, Team 2-3, Morris Spring 2024 crwdns2935289:0UC Davis, Team 2-3, Morris Spring 2024crwdne2935289:0
UCD-MORRIS-S24S2G3
crwdns2936753:030crwdne2936753:0 74
crwdns2942667:0crwdne2942667:0 776
