This guide will help you change the power buttons if your buttons either break or get stuck.
Be sure to have device off before beginning.
Unplug the microphone from the headset.
Remove the old cushion by pulling it off from the edge and out from the grooves.
Continue to pull the cushion away from the speaker until the cushion is fully separated.
Remove four 6 mm Phillips #1 screws that secure the cover.
Lift off the cover.
Remove the single 6 mm Phillips screws that secures the volume control knob.
Remove the button by pulling them from the casing with your hands.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
That is mute button not power button
