Razer Barracuda X Motherboard Replacement
  1. Razer Barracuda X Motherboard Replacement, Motherboard: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Razer Barracuda X Motherboard Replacement, Motherboard: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the cushion by pulling it off from the edge and out from the grooves, Continue to pull the cushion away from the speaker until the cushion is fully separated.
  2. Razer Barracuda X Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Razer Barracuda X Motherboard Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Razer Barracuda X Motherboard Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a Phillips #0 screwdriver to unscrew the four screws that attach the two pieces of the right speaker together.
    • Gently lift the plastic plate away from the housing, with care not to damage the connected wire.
  3. Razer Barracuda X Motherboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a Phillips #0 screwdriver, remove the single screw attaching the volume spinner to the motherboard.
    • Remove the spinner.
  4. Razer Barracuda X Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the Phillips #0 screws securing the I/O board from the bottom shell of the right speaker.
    what size and how many pins have that ribbon cable
    Melz - crwdns2934203:0crwdne2934203:0
  5. Razer Barracuda X Motherboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Razer Barracuda X Motherboard Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • To fully remove the I/O board from the right speaker, use tweezers to unplug the ribbon cable attaching the I/O board to the main motherboard.
  6. Razer Barracuda X Motherboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the same Philips #0 screwdriver, remove the four screws attaching the motherboard to the plastic housing. Once those screws are removed, remove the main motherboard and replace it.
  7. Razer Barracuda X Motherboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Razer Barracuda X Motherboard Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Razer Barracuda X Motherboard Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Desolder all of the remaining motherboard connections.
    • Do not hold the iron by the barrel as depicted in the images.
    • Remove the motherboard.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Josiah Cassidy
crwdns2935283:010/26/22crwdne2935283:0
244 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 2-3, Petersen Fall 2022 crwdns2935289:0UMass Dartmouth, Team 2-3, Petersen Fall 2022crwdne2935289:0
UMASSD-PETERSEN-F22S2G3
crwdns2947412:05crwdne2947412:0
Now if I could just find somewhere to buy the I/O board. My volume slider is crackling and sometimes one cup is louder than the other.
Michael Nugent - crwdns2934203:0crwdne2934203:0
You ever find a replacement?
Gaelan Garrett -
i found that submerging the volume dial in Isopropyl alcohol and moving the volume up and down cleans the wheel internal contacts and it no longer has this issue.
Mexicanskynet -
@mexicanskynet what did you submerge exactly? the spinner or the mechanizm under it?
suny set -
@michaelnugent My volume wheel just broke too! Must be a weak point in the design.
Michael Shu - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 40
crwdns2936753:030crwdne2936753:0 161
crwdns2942667:0crwdne2942667:0 4,612
