This repair guide will show you how to replace the battery from your Razer Barracuda X headphones.
If the battery is swollen, take precautions.
Attempt to dispose of the battery responsibly (It may be the law in your area).
For best results, after installing a new battery, calibrate it.
Remove the cushion by pulling it off from the edge and out from the grooves.
Continue to pull the cushion away from the speaker until the cushion is fully separated.
Remove the four 6 mm Phillips #1 screws from the left side of the speaker casing.
Gently pull the speaker casing away from the shell.
Place it face down to access the battery.
Unplug the battery from the socket.
Use a spudger to gently lift the battery up.
Remove the battery.
crwdns2947412:07crwdne2947412:0
What is the voltage of the battery?
It’s a 3.7V battery.
Battery info Barracuda X Wireless (2022) version but I believe the non 2022 version also:
55345PN2 / 1ICP6/35/51 1200mAh/4.44Wh
Dominick -
Si, 3,7 v se ve muy mal en la foto del Paso 4
Carlos López (España - Spain) - crwdns2934203:0crwdne2934203:0
How small is that battery?? i took mine apart and i saw i got the wrong size battery in general.
what is the capacity of the battery in mAh for the 2022 50 Hours life razer?
Dominick -
