Punkt MP02 Keyboard Membrane Replacement
crwdns2869540:0crwdne2869540:0: 291
2
29
84
291
crwdns2955950:0crwdne2955950:0: 2
crwdns2960004:02crwdne2960004:0.
crwdns2959984:0crwdne2959984:0: 0
crwdns2959956:0crwdne2959956:0
crwdns2955944:0crwdne2955944:0: crwdns2931287:025crwdne2931287:0
If your keys for your Punkt MP02 are damaged or faded, you can follow these steps to help you replace the keyboard membrane. A damaged membrane should often be replaced because it can cause mis-clicks or frustration when typing. However, check out our troubleshooting guide for "buttons not registering" first to ensure it is hardware and not software-related. Before you begin, backup important data, and power off the device to ensure no data loss throughout the process.
    1. Punkt MP02 Keyboard Membrane Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Punkt MP02 Keyboard Membrane Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use a SIM card eject tool to to eject and remove the SIM card tray on the side of the phone.
    2. Punkt MP02 Keyboard Membrane Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Punkt MP02 Keyboard Membrane Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • The back panel is held on by glue and multiple tabs.
      • Slide a Jimmy into the seam between the back panel and the chassis.
      • Slide the Jimmy around the perimeter to release the back panel, with care not to damage the retaining clips.
      • Clean any old adhesive with a spudger and isopropyl alcohol, then apply new adhesive to the back panel before reinstalling it.
    3. Punkt MP02 Keyboard Membrane Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Punkt MP02 Keyboard Membrane Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Punkt MP02 Keyboard Membrane Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Use a Phillips screwdriver to remove the two adjacent 3 mm Phillips screws.
    4. Punkt MP02 Keyboard Membrane Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Punkt MP02 Keyboard Membrane Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Punkt MP02 Keyboard Membrane Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Insert a Jimmy into the seam between the front and back case.
      • Slide the Jimmy around the perimeter while prying to separate the front and back case.
    5. Punkt MP02 Keyboard Membrane Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Punkt MP02 Keyboard Membrane Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use a spudger to pry up and disconnect the battery press connector.
      • Make sure to pry under the connector itself and not on the board.
    6. Punkt MP02 Keyboard Membrane Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Punkt MP02 Keyboard Membrane Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Gently pry the battery off with the spudger tool.
      • Take care not to bend, warp, or puncture the battery during removal.
    1. Punkt MP02 Keyboard Membrane Replacement, Screen: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Punkt MP02 Keyboard Membrane Replacement, Screen: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Punkt MP02 Keyboard Membrane Replacement, Screen: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove the six 3 mm-long Phillips screws located on the board beneath the battery.
    2. Punkt MP02 Keyboard Membrane Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Punkt MP02 Keyboard Membrane Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Punkt MP02 Keyboard Membrane Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove the antenna coaxial connectors on the board with a spudger by gently prying straight up where they are connected on the board.
    3. Punkt MP02 Keyboard Membrane Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Punkt MP02 Keyboard Membrane Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Punkt MP02 Keyboard Membrane Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Flip up the two black locking flaps securing each of the two ribbon cables.
      • Disconnect the two ribbon cables.
    4. Punkt MP02 Keyboard Membrane Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Punkt MP02 Keyboard Membrane Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Using your thumbs, push the board up so that the clip can slide out of the indent.
      • Use a spudger to gently separate the boards.
      • Ensure that the antennae slide through the holes—do not accidentally pull these off.
    5. Punkt MP02 Keyboard Membrane Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Punkt MP02 Keyboard Membrane Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Punkt MP02 Keyboard Membrane Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Use a spudger to lift and disconnect the screen press connector.
      • Make sure to pry up on the edge of the connector, not the board itself.
      • Remove the screen.
    1. Punkt MP02 Keyboard Membrane Replacement, Keyboard Membrane: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Punkt MP02 Keyboard Membrane Replacement, Keyboard Membrane: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Punkt MP02 Keyboard Membrane Replacement, Keyboard Membrane: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove the 3 (3mm) Phillips head screws from the board.
    2. Punkt MP02 Keyboard Membrane Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Punkt MP02 Keyboard Membrane Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use a spudger to gently pry the board up and remove it.
    3. Punkt MP02 Keyboard Membrane Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Punkt MP02 Keyboard Membrane Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Punkt MP02 Keyboard Membrane Replacement: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Peel the keyboard membrane off the phone casing.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Gloria Enchill
crwdns2935283:002/19/26crwdne2935283:0
97 crwdns2915208:0crwdne2915208:0
University of Memphis, Team 1-3, Sneed Spring 2026 crwdns2935289:0University of Memphis, Team 1-3, Sneed Spring 2026crwdne2935289:0
UM-SNEED-S26S1G3
crwdns2936753:07crwdne2936753:0 29
crwdns2936753:030crwdne2936753:0 84
crwdns2959996:0crwdne2959996:0 291
