This guide will explain how to replace a motor of the Protocol Kaptur GPS drone.
The battery is accessible through the back of the drone.
Press the tabs on both sides of the white stripe to pull the battery out.
Remove the screws starting with the three smaller ones on the top part of the battery.
Remove the three screws on the other side.
There are two screws tucked under where the yellow circle is located. You will need to remove the other screws first before you get to these two.
Remove the top piece, and gently pry the two halves apart. Divide the sticker if necessary.
The battery is now removable from its container.
Remove the 4x 7mm Phillips head screws on the outside of the shell, and the 2x 5mm Phillips head screws from the middle, then remove the back part of the housing.
Remove the two hidden screws at the bottom, and the white power button.
Unplug all the cords from the circuit boards.
Carefully slide the main body off of the arms.
Remove all screws from all four arms, and the screws on either side of the center.
The screws on the arms are 7mm.
The screws on the motor are 9mm.
Remove the 5mm screw holding the rotor onto the drone.
Gently pry apart the upper and lower part of the shell by working the opening tool along the middle seam.
Unscrew the motor screws, and remove the motor.
Pry up the middle portion of the arm to access the cables.
Remove the motor by unsoldering the cords from the main circuit board.
crwdns2935229:09crwdne2935229:0
crwdns2947412:011crwdne2947412:0
What size and rpm does it take, but also is there a way to upgrade the motors for more punch?
Thank you.for your information and time to make my grandson
What size is the main gear??
2.0
I believe
Anyone else having a problem with the props twisting on the shaft during flight
