Protocol Galileo Stealth Pinion Gear Replacement
  1. Protocol Galileo Stealth Pinion Gear Replacement, Propeller: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the chrome shaft cover by lightly pulling it away from the drone.
  2. Protocol Galileo Stealth Pinion Gear Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a Phillips #000 screwdriver, remove the 7mm screw from the propeller stop.
    • Be sure to apply adequate pressure when removing the screw to prevent stripping it out.
  3. Protocol Galileo Stealth Pinion Gear Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the propeller stop from shaft by lightly pulling it away from the drone.
  4. Protocol Galileo Stealth Pinion Gear Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the propeller from shaft by lightly pulling it away from the drone.
  5. Protocol Galileo Stealth Pinion Gear Replacement, Housing: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Protocol Galileo Stealth Pinion Gear Replacement, Housing: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 8mm long Phillips #0 screws (24 total) from the lower housing unit.
    • Take care to place the screws in a safe place to prevent losing them.
  6. Protocol Galileo Stealth Pinion Gear Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Separate the upper and lower housing units by lightly pulling the two housing units apart.
  7. Protocol Galileo Stealth Pinion Gear Replacement, Pinion Gear: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the pinion gear off the motor shaft by lightly pulling it away from the drone.
Matthew Selting
crwdns2935283:002/15/18crwdne2935283:0
453 crwdns2915208:0crwdne2915208:0
UW Stout, Team S8-G4, Ogden Spring 2018 crwdns2935289:0UW Stout, Team S8-G4, Ogden Spring 2018crwdne2935289:0
UWSTOUT-OGDEN-S18S8G4
crwdns2942667:0crwdne2942667:0 274
