PowerShot G7 X Mark II LCD Screen Replacement
  1. PowerShot G7 X Mark II LCD Screen Replacement, LCD Screen: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Philips #000 screwdriver to remove the three 2mm screws on the bottom of the LCD screen.
  2. PowerShot G7 X Mark II LCD Screen Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Tilt the LCD screen all the way up and use a Phillips #000 screwdriver to remove the three 4mm screws from the back of the LCD screen.
  3. PowerShot G7 X Mark II LCD Screen Replacement, Remove back panel from LCD screen: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a spudger tool to release the ribbon cable from the ZIF connector.
    • The cable is thin and delicate. Detach with care.
    • Gently pry off the screen until the double-sided tape behind the back panel gives in.
    there's a small square of glue gum near the middle 4mm screw (from step 2). It holds the black plastic part and the LCD screen together. You can see the square gum on step 4 photo.
    You'll have to pull a bit (gently) to detach the screen.
    oluc - crwdns2934203:0crwdne2934203:0
  4. PowerShot G7 X Mark II LCD Screen Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The screen is detached and can now be replaced.
    Do the replacement screens keep the touchscreen functionality of the camera? Do you know of any good sources to buy the replacement screen from?
    Steve Beecheno - crwdns2934203:0crwdne2934203:0
crwdns2935229:05crwdne2935229:0
Brandon
crwdns2935283:002/15/17crwdne2935283:0
644 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 12-3, Eyestone Spring 2017 crwdns2935289:0USF Tampa, Team 12-3, Eyestone Spring 2017crwdne2935289:0
USFT-EYESTONE-S17S12G3
crwdns2947412:05crwdne2947412:0
Are there any problems with the replacement screen? It’s a touch screen, just making sure the functionality of the screen is still intact.
Andrew Baez - crwdns2934203:0crwdne2934203:0
These directions do not give enough information. The screed is glued into the frame. The replacement parts do not come with the circuit board.
alan saltus - crwdns2934203:0crwdne2934203:0
Did you successfully replace the screen? I took off the screws, and got to the detaching the wire stage but then discovered as you said “the glue”. Any further insight would be appreciated!
rachelkernali -
My G7X lost one of the 2 screws holding the screen: do you know where I can find them?
paolofarinella - crwdns2934203:0crwdne2934203:0
on ebay or amazon. you can order it
nicole -
crwdns2936753:07crwdne2936753:0 33
crwdns2936753:030crwdne2936753:0 171
crwdns2942667:0crwdne2942667:0 9,566
