PowerShot G7 X Mark II Front Cover Replacement
  1. PowerShot G7 X Mark II Front Cover Replacement, Top Cover Button Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PowerShot G7 X Mark II Front Cover Replacement, Top Cover Button Panel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #000 screwdriver to remove four 4mm screws from the NFC panel cover on the bottom of the camera.
  2. PowerShot G7 X Mark II Front Cover Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PowerShot G7 X Mark II Front Cover Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #000 screwdriver to remove five screws from under the LCD screen:
    • Three 2.4 mm screws
    • Two 3 mm screws
  3. PowerShot G7 X Mark II Front Cover Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #000 screwdriver to remove two 3mm screws on the left of the camera.
    the other screw (on the top) must be removed too
    oluc - crwdns2934203:0crwdne2934203:0
  4. PowerShot G7 X Mark II Front Cover Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PowerShot G7 X Mark II Front Cover Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #000 screwdriver to remove one 3mm and one 4mm screw on the surface of the right face of the camera, and one under the USB/HDMI cover.
    Use a Phillips #000 screwdriver to remove one ~6mm above the button and one 4mm screw bellow the button on the surface of the right face of the camera. Additionally, one 3mm under the USB/HDMI cover.
    Andrew Grasman - crwdns2934203:0crwdne2934203:0
  5. PowerShot G7 X Mark II Front Cover Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PowerShot G7 X Mark II Front Cover Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully remove the back cover off of the camera by hand. Press the brown actuator in the FFC socket to release the FPC (Flexible Printed Circuit - brown cable attached to the back cover) and pull the FPC out of the socket.
    • If the FPC doesn't come out easily, you haven't yet released it. Do not force it. Do not use a spudger because it will break the socket. A broken socket cannot be fixed and has to be replaced by a skilled technician.
  6. PowerShot G7 X Mark II Front Cover Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PowerShot G7 X Mark II Front Cover Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #000 screwdriver to remove two 3mm screws on the pop-up flash.
    and unclip the top hat of the pop-up flash, then push the flash back in place.
    This is needed to be able to remove completely the top cover.
    ~2.6 ish mm and thinner, not like the other 3mm
  7. PowerShot G7 X Mark II Front Cover Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PowerShot G7 X Mark II Front Cover Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #000 screwdriver to remove two 2mm screws attaching the button panel to the camera body.
    • Use a Phillips #000 screwdriver to remove a 3mm screw from beneath the mode dial.
  8. PowerShot G7 X Mark II Front Cover Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 PowerShot G7 X Mark II Front Cover Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 PowerShot G7 X Mark II Front Cover Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Open the battery compartment and remove the battery by flipping the small latch holding it in.
    • Use a Phillips #000 screwdriver to remove one 6mm screw in the bottom of the battery compartment.
    Wow I removed the battery before Step 1!!!
    JOHN J GRAY - crwdns2934203:0crwdne2934203:0
  9. PowerShot G7 X Mark II Front Cover Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PowerShot G7 X Mark II Front Cover Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pry the top cover button assembly off of the camera body by detaching clips around the base of it.
    first, detach the ZIF connector
    be careful when detaching the top cover : there's a small metallic part that is loose and will fall.
    This part is a ~10mm bent metal strip, with a screw hole.
    When in place it holds with the long screw from the battery compartment (step 8)
    hi can u please help me remove the dial wheel on the upper cover. mine become stuck and i am hoping that you could help me fix it.. thankyouu
    keith. - crwdns2934203:0crwdne2934203:0
    please do a tutorial on how to remove the dial wheel on upper cover..
  10. PowerShot G7 X Mark II Front Cover Replacement, Front Cover: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #000 screwdriver to remove two 3mm screws on the left and one 5mm screw on the right from the front panel.
    I got
    - two 4mm screws on the left (golden-ish)
    - one 3mm screw on the right (silver)
    (rather than “two 3mm and one 5mm”)
  11. PowerShot G7 X Mark II Front Cover Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the USB/HDMI panel from the right side of the camera.
  12. PowerShot G7 X Mark II Front Cover Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Separate the front cover and focus ring assembly from the front of the camera. Use a plastic spudger to detach the ZIF connector holding the ribbon cable connected to the focus assembly.
    That ZIF connector in step 12 was really hard to detach so I think I broke one of those little holders for it. Is there any replacement ribbon with those holders? What are my options?
    Bartol Filić - crwdns2934203:0crwdne2934203:0
    actually it's not a ZIF connector, so don't try to pull/push the grey “box”, you'll break it.
    It's a basic connector/socket : just gently pull the ribbon.
    you can see it for example (at 7”20’)
    https://www.youtube.com/watch?v=v0vso3CI...
Brandon
crwdns2935283:002/15/17crwdne2935283:0
626 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 12-3, Eyestone Spring 2017 crwdns2935289:0USF Tampa, Team 12-3, Eyestone Spring 2017crwdne2935289:0
USFT-EYESTONE-S17S12G3
thank you so much for the guide!! extremely helpful, clear pictures, and easy to understand instructions.
victoria - crwdns2934203:0crwdne2934203:0
Please give instructions how to disassemble the flash and replace the flash capacitor. Thank you very much
Momchil Panayotov - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 36
crwdns2942667:0crwdne2942667:0 4,354
