PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) RAM Replacement
  1. PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) RAM Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) RAM Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your thumbs to push the two battery retaining tabs away from the battery.
    • The battery should pop up enough to rotate it toward yourself and lift it out of the lower case.
  2. PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) RAM Replacement, Memory Door: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the three 2.3 mm Phillips screws securing the memory cover to the lower case.
  3. PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) RAM Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) RAM Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the memory cover slightly and pull it toward yourself to remove it from the lower case.
  4. PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) RAM Replacement, RAM: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) RAM Replacement, RAM: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) RAM Replacement, RAM: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your fingertips to pull the two RAM arms away from the sides of the RAM chip. The chip should pop up slightly.
    • Pull the RAM chip away from its socket and remove it from the logic board.
    • Repeat this process for the other RAM chip, if present.
crwdns2935229:024crwdne2935229:0
crwdns2935103:0crwdne2935103:0
Walter Galan
702,693 crwdns2915208:0crwdne2915208:0
crwdns2935297:01,203crwdne2935297:0
What is the maximum ram that I can bump up this system to?
Legendary Ocelot - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 8,447
