If your display is broken or damaged you will need to replace the entire display.
Close the screen and turn the PowerBook over, orienting the computer upside down, using the label to guide you.
Hold the button on the front left side and slide the battery out.
With a Torx T8 screwdriver, remove the three Torx 24mm screws along the center of the back panel.
Turn the computer over and open the display. You should see that the keyboard is loose.
Slightly lift the front of the keyboard up, and slide the keyboard towards yourself.
Carefully lift the top half of the keyboard and pull it towards yourself.
Loosen the ribbon cables connecting the keyboard to the computer by using a plastic opening tool to lift the tabs on either side of the cable port.
Gently remove the ribbons from its tabs.
I did find that, strictly speaking, you don’t need to remove the ribbons. If you carefully hold up the keyboard up towards the screen with one hand, you can remove the old RAM and install the new one with the other. I suppose you could also use a length of masking tape to hold the keyboard up.
I found it easier not to remove the ribbon, especially as I couldn’t find my plastic opening tool.
Gently wiggle the RAM card to loosen the connection until it pulls free.
Disconnect the wires from the port.
Speaker panel? I don’t think this is correct - I accidently pulled the black & red wires out from this part and sound still worked fine. Is this instead a battery connection?
thats correct, that red/black wire comes from the green Varta battery under the speaker panel. This PRAM battery most of the time has gone bad since the 90s and it's electrolyte fluid dropped down onto the main board, destroying other parts.
Remove the 7mm screw connecting the speaker panel to the computer.
To detach the speaker panel's ribbon cable, use a plastic opening tool to lift the tabs on both sides of the cable port.
Once loose, pull the ribbon cable free.
Lift the lighting/audio panel from it's bottom corners and pull the panel towards yourself.
Remove the panels on either side by gently but firmly pulling up on them with both hands.
gently, because there is this tiny green connector board with its two little buttons for PCMCIA cards ejection stuck in directly under it/ hold in place.
Gently pull up on the ribbon cable connection that connects the screen to the logic board.
Remove the two T8 13 mm long torx screws on either side of the display, located under the side panels.
Gently pull the display free of the computer.
To replace the display, follow these instructions in reverse order.
Note that the side panels should be placed back BEFORE the audio panel.
right, also I often had problems with placing the audio panel back into its place, it's three little plastic noses just didnt want to fit back into its notches of the back.
