Battery is located in the right side headphone housing.
Use a heat gun with temperature set to 140 F for about 2-3 minutes and heat the casing where it attaches together as seen in the picture.
After heating for about 2-3 minutes, separate the housing using a pry tool as seen in the pictures.
Use a soldering iron to desolder battery connection to remove battery and replace with new one.
At this point what the f*** is the point in having it
Yeah.. no $@$*!!! Ridiculous to have these things for not even 3 months and I'm having to deal with this nonsense..
Tell us where to connect the wires in the battery based on colors, please. The red and the green ones we can see on the pictures but the other 5 are twisted, impossible to identify.
P± T P- must be checked carefully when disconnecting the battery.
P+ is + for power supply and - for the same.
T is thought to stand for Thermistor.
Replacement batteries usually have three wires: red, white, and black. Red is +, black is -, and white is Thermistor.
Green+
Red/Gold -
Red Thermistor
crwdns2935229:013crwdne2935229:0
crwdns2947412:05crwdne2947412:0
If you need this part you can order it here
My battery only was connected by two wires. Is that a newer edition of the Powerbeats than this one? Has Apple changed their wiring?
Where can I get the batteries? Is it available besides beats showroom?
My bettry is too good work but tha wireis want to b change
Plzz tel me how I can change tha wire of my power beats
