Buttons are a crucial part of any controller. However, after extended use, whether regular or light, the buttons will wear down. This guide will show you how to replace the buttons on your controller. Please note that this guide is for replacing the buttons, not the circuitry attached to them. If the buttons are acting strange, for instance reading a tap as a double tap, this guide may not help.
Remove the (9) nine 9.2mm screws with a JIS #1 screwdriver.
Remove the two bottom plastic grip covers.
Remove the (2) two 9.2mm screws with a JIS #1 screwdriver.
Remove the back cover of the controller.
Would have been a better guide if you actually used a power a fusion controller.
This is just a normal power a controller.
Fusion has detachable cable and 4 detachable paddles on the back.
Lol
Remove the (5) five 9.2mm screws with a JIS #1 screwdriver.
Lift the motherboard and let it hang.
Remove the (4) four 9.2mm screws that are holding the motherboard to the controller.
Put the motherboard aside.
Go back to the motherboard, and remove the buttons' gasket with a tweezler.
What do you do after you remove the button gasket
Do the buttons come with the gasket? Also the buttons are for an Xbox One controller. Does that mean they are compatible?
crwdns2935229:010crwdne2935229:0
Okay so what do you do if by any chance one of the links that are sawdered to the mother board for the D Pad Connection cable breaks… Then what? How would I go about fixing that????
is there a guide to clean the bumpers out? my RB became less consistent and i'm hoping it's just because they're gunked up
