crwdns2937539:0crwdnd2937539:0crwdne2937539:0
Almost all gas now contains up to 10% ethanol. Ethanol is one of the leading causes of damage to small gas engines. The alcohol can cause corrosion on rubber and plastic parts and can make gas powered yard tools almost impossible to start. I will illustrate how to replace the parts that are most common to fail,the primer bulb and fuel lines. While disassembled I will also illustrate how to replace the fuel filter and air filter of the Poulan P3314 2-Cycle Chainsaw.
Start by unscrewing the (3) T25 screws on the top cover
Remove the top cover and set aside
With the top cover off, disconnect the sparkplug
Remove the (4) T25 screws securing the starter assembly to the (side) of the chainsaw
Remove the starter assembly and set aside
Remove the air filter cover and set aside
Remove the air filter from the housing and set aside
Unscrew the (1) T25 screw securing the air filter housing to the carburetor
Remove the (2) 5/16"nuts securing the air filter housing to the carburetor
Disconnect the kill switch wire by using a flat head screw driver
Remove the air filter housing from the carburetor
Let the air filter housing rest on the side of the chainsaw
Using a flat head screw driver disconnect the (primer-side) fuel line from the carburetor.
Remove the choke lever from the carburetor and set aside
Pull and hold the throttle trigger to expose the throttle linkage attachment point (on the trigger)
Disconnect the linkage from the throttle trigger
Disconnect and remove the throttle linkage from the carburetor
Set the throttle linkage aside
Slide the carburetor assembly off the mounting bolts and away from the engine
Using a flat head screwdriver press the tabs on the inside of the primer bulb assembly. (This will release the primer bulb from the housing)
Pull the damaged primer bulb out of the engine housing
Use long needle nosed pliers to disconnect the (2) fuel lines from the primer bulb.
If the primer suction line was damaged, slide the carburetor back onto the mounting bolts
Attach one end of the new fuel line to the incoming fuel port on the carburetor
Move the fuel line through the primer bulb housing and hold the primer bulb up to the fuel line
Mark desired length and cut to size
Attach the cut end of the primer fuel line to the intake port of the primer bulb (shorter nipple)
Slide the carburetor back off of the mounting bolts
Cut and remove the remaining old fuel lines by pulling them through the housing
Unscrew and remove the gas cap
Pull out and remove old fuel lines and fuel filter
Push a piece of scrap wire through the larger hole (fuel filter line)
Use a pair of long needle nose pliers or hemostats to grab the other end through the gas tank
Cut a piece of the thicker diameter fuel line at a sharp angle
Pierce the wire through the fuel line and twist the wire with pliers
Feed the fuel line through the gas tank while pulling the wire.
Use pliers to continue to pull the fuel line through the housing
Feed the wire through the small hole (fuel return)
Feed the fuel line through the gas tank while pulling the wire as in the previous step
Pull both fuel lines up through the housing
Cut both of the fuel lines flush (removing the angle that was previously cut)
Attach the larger diameter fuel line (fuel filter line) to the intake inlet on the carburetor
Attach the smaller diameter fuel line (fuel return line) to the return port on the primer bulb (longer nipple)
Slide the carburetor back onto the mounting bolts while pulling out the slack out of the fuel lines from the gas tank
Push the primer bulb back into the housing
Cut the smaller diameter fuel line (fuel return line) and push it into the gas tank
Cut the fuel filter line and attach the new fuel filter
Push the fuel filter line into the gas tank
Reconnect the throttle linkage to the carburetor linkage
Pull and hold the throttle trigger to expose the attachment point for the trigger-portion of the throttle linkage
Connect the throttle linkage to the throttle trigger
Reconnect the choke lever
Slide the air filter housing back onto the carburetor mounting bolts
Secure the air filter housing with the (2) 5/16" nuts
Secure air filter housing with (1) T25 screw
Install the new air filter onto the air filter housing
Install the air filter cover
Connect the kills witch wire
Install the starter assembly onto the engine
Secure the starter assembly with (4) T25 screws
Pull the starter rope slowly until the flywheel engages the starter assembly
Reconnect the spark plug
Install the top cover and secure with (3) T25 screws
crwdns2935229:038crwdne2935229:0
crwdns2944067:020crwdne2944067:0
Any idea where I downloaded shop manuals for small engin repairs looking for stihl 039 manual
Yes I would try manuals.lib at the Google play store.
Daniel. Here you go. Hope this works out for you.
Excellent instructions
Thank You
How do you choose the best choose the best product among the ones listed here? <a href="https://onlychainsaw.com/best-scroll-saw... ">https://onlychainsaw.com/best-scroll-saw... </a>
