Portable Power Station Battery Replacement
  1. Portable Power Station Battery Replacement, Shut down your power station: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Portable Power Station Battery Replacement, Shut down your power station: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Portable Power Station Battery Replacement, Shut down your power station: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Let your Portable Power Station's battery drain below 25% before starting this repair. A charged lithium‑ion battery may catch fire if damaged.
    • Hold down the blue action button for five seconds to shut down your power station.
    • Collapse the kickstand.
  2. Portable Power Station Battery Replacement, Remove the rear cover screws: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Portable Power Station Battery Replacement, Remove the rear cover screws: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    FixMat
    $36.95
    • Use a T10 Torx screwdriver to remove the two 8 mm‑long screws securing the rear cover.
  3. Portable Power Station Battery Replacement, Remove the rear cover: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Portable Power Station Battery Replacement, Remove the rear cover: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Portable Power Station Battery Replacement, Remove the rear cover: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Grab the rear cover and pull the bottom edge towards you.
    • Remove the rear cover.
    • Don't try to remove the enclosure while the battery is still connected, or you'll damage the battery connector.
    • During reassembly, hook in the top edge of the rear cover first, then press the bottom edge into place.
  4. Portable Power Station Battery Replacement, Pry up the battery connector: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Portable Power Station Battery Replacement, Pry up the battery connector: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • To avoid an electrical shock, don't use metal tools to disconnect the battery.
    • Insert the flat end of a spudger into one of the slots on either side of the battery connector. They're shaped just for this!
    • Use the spudger to begin prying up the connector.
    • If it's your first time disconnecting the battery, this may take some force.
  5. Portable Power Station Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Portable Power Station Battery Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Portable Power Station Battery Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Repeat the process and pry up on alternating sides of the battery connector to "walk" it off of the two plugs, enough that you can easily grip it with your fingers.
    • You may have to reposition your spudger to fully release the battery connector. Be careful not to damage the board if you pry against it.
  6. Portable Power Station Battery Replacement, Disconnect the battery: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Portable Power Station Battery Replacement, Disconnect the battery: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Don't try to force the connector off or you might hurt yourself on the metal edges of the enclosure. If the connector doesn't come off easily, continue prying up with your spudger until the connector is loose enough to easily disconnect.
    • Grasp the battery connector by its edges and pull straight up to disconnect it.
  7. Portable Power Station Battery Replacement, Reassembly information: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Portable Power Station Battery Replacement, Reassembly information: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Portable Power Station Battery Replacement, Reassembly information: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • During reassembly, follow these steps to reconnect the battery:
    • Tuck the wires behind the connector, so the side of the connector with positive (+) and negative (-) markings is facing outward.
    • Make sure the wires aren't pinched by the enclosure.
    • Align the connector over its two metal plugs so the negative (-) side is on the left of the USB‑C port and the positive (+) side is on the right.
    • Slide the connector onto its plugs and push down firmly until it's fully seated.
  8. Portable Power Station Battery Replacement, Remove the chassis: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Portable Power Station Battery Replacement, Remove the chassis: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Place your fingers on the rear cover screw holes and push the chassis slightly out of the enclosure.
  9. Portable Power Station Battery Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Portable Power Station Battery Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Portable Power Station Battery Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the chassis fully out of the enclosure, making sure the battery connector doesn't get snagged.
    • During reassembly:
    • Make sure the battery is disconnected before sliding the chassis into the enclosure. Otherwise, you'll damage the battery connector.
    • Insert the battery connector side of the chassis into the end of the enclosure closest to the kickstand and slide it into place.
  10. Portable Power Station Battery Replacement, Remove the metal battery cover: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Portable Power Station Battery Replacement, Remove the metal battery cover: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the flat end of a spudger or a clean fingernail to pry up the edge of the metal battery cover closest to the battery connector.
  11. Portable Power Station Battery Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Portable Power Station Battery Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Portable Power Station Battery Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The battery cover locks the battery in place. Once removed, the battery becomes free to fall out of the power station.
    • Remove the metal battery cover.
    • Hook the short edge of the cover without cutouts into place at the front, near the display.
    • Firmly press down on the opposite edge of the cover until it clips into place.
    • Make sure the battery cover doesn't pinch the battery cables—they should be routed under the cover and angled inward.
  12. Portable Power Station Battery Replacement, Remove the battery: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Portable Power Station Battery Replacement, Remove the battery: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Portable Power Station Battery Replacement, Remove the battery: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the battery.
    • During reassembly, don't reconnect the battery until after the enclosure is installed, or you'll damage the battery connector when everything goes back together.
To reassemble your Portable Power Station, follow these instructions in reverse order.
Calibrate your newly installed battery after completing this guide.
Nick Schultz
crwdns2935283:003/24/24crwdne2935283:0
19,612 crwdns2915208:0crwdne2915208:0
crwdns2935297:0114crwdne2935297:0
Staff
crwdns2931471:0120crwdne2931471:0
crwdns2935297:019,995crwdne2935297:0
crwdns2936753:07crwdne2936753:0 48
crwdns2936753:030crwdne2936753:0 156
crwdns2942667:0crwdne2942667:0 1,186
