Polaroid Onestep Close Up Close Up Lens Replacement
  1. Polaroid Onestep Close Up Close Up Lens Replacement, Flash Assembly Removal: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Polaroid Onestep Close Up Close Up Lens Replacement, Flash Assembly Removal: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Polaroid Onestep Close Up Close Up Lens Replacement, Flash Assembly Removal: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Begin by opening the top of the camera (flash assembly) to a slight angle.
    • Next, angle the flash assembly slightly upward and pry off the connections carefully.
    • Be careful not to damage the ribbon cable. This is essential to the operation of the flash.
    Lens Replacement Guide - Steps 5 through 8 need titles
    Step 6 - remove first bullet
    Step 2 - 3 need titles
    Add titles to all steps of all guides
    Primary lens replacement guide
    Step 4 is not a step review titles for all steps.
    hani - crwdns2934203:0crwdne2934203:0
    Proofread your guides carefully.
    Dan Brown - crwdns2934203:0crwdne2934203:0
  2. Polaroid Onestep Close Up Close Up Lens Replacement, Opening Film Tray: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Polaroid Onestep Close Up Close Up Lens Replacement, Opening Film Tray: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the action button, on the bottom of the camera, to open the bottom.
  3. Polaroid Onestep Close Up Close Up Lens Replacement, Removing Face Plate: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Polaroid Onestep Close Up Close Up Lens Replacement, Removing Face Plate: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Polaroid Onestep Close Up Close Up Lens Replacement, Removing Face Plate: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the blue plastic opening tool between the rear case and the plastic tabs directly under the shelf, and pry it loose.
    • Pull off the face plate.
  4. Polaroid Onestep Close Up Close Up Lens Replacement, Removing the slider: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pry off the slider (the light gray piece) by slipping it out from beneath the tabs (their location is indicated by the two red circles).
  5. Polaroid Onestep Close Up Close Up Lens Replacement, Removing the Face Plate: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Polaroid Onestep Close Up Close Up Lens Replacement, Removing the Face Plate: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Polaroid Onestep Close Up Close Up Lens Replacement, Removing the Face Plate: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pry off the face plate at the locations shown by using a rigid prying tool (either tweezers or the blue plastic opening tool). These spaces can be very tight.
    • You'll know if you were successful if you can fully remove the face plate.
  6. Polaroid Onestep Close Up Close Up Lens Replacement, Removing the Spring: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Polaroid Onestep Close Up Close Up Lens Replacement, Removing the Spring: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers to lift the ring of the spring off of the hook it is attached to.
    • Gently loosen and remove the spring.
  7. Polaroid Onestep Close Up Close Up Lens Replacement, Removing the First Part of the Close Up Lens: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Polaroid Onestep Close Up Close Up Lens Replacement, Removing the First Part of the Close Up Lens: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the CloseUp lens piece all the way to the left. It should separate without any resistance.
  8. Polaroid Onestep Close Up Close Up Lens Replacement, Removing the Second Part of the Close Up Lens: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Polaroid Onestep Close Up Close Up Lens Replacement, Removing the Second Part of the Close Up Lens: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Make sure the last plastic piece is set all the way to the right. Using the blue plastic tool, pry it loose. It should easily pop out.
Jordan
crwdns2935283:009/22/14crwdne2935283:0
471 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 3-5, Brown Fall 2014 crwdns2935289:0USF Tampa, Team 3-5, Brown Fall 2014crwdne2935289:0
USFT-BROWN-F14S3G5
Which model is the "precious" one?
anyone know where i can buy the close up lens?
finbarlaverty - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 2,041
