Remove the eight, 7.4 millimeter-long screws on the back of the watch with a T5 head-type, torque screwdriver.
Gently separate the watch housing from the back panel.
Remove the nine, 4.0 millimeter-long screws with a T5 head-type torque screwdriver.
Once all of the screws have been removed, lift the motherboard to expose the battery beneath motherboard.
Use a spudger to pry the battery from the back of the watch.
Original: 3.7 V 442830
Replacement: 3.7 V 453030
Aliexpress.com
Gently pull the wires from their solder joints to disconnect them from the body of the watch.
Where can the replacement motherboard be bought? Thanks
Bonjour et merci pour ses photos ezt explication, mais savez vous ou commander le joint rouge entourant et faisant l “ étanchéité de celle ci. Merci
