This guide will show users how to replace the display (not the glass screen) on the Polar V800 sports watch. If the display has damaged pixels or no longer operates properly, the display may need to be replaced to keep your watch functional.
Remove the eight, 7.4 millimeter-long screws on the back of the watch with a T5 head-type, torque screwdriver.
Gently separate the watch housing from the back panel.
Place a T5 torque screwdriver in the upper right and lower left diagonal 4mm screws that hold the white plastic down and rotate the screwdriver to the left, removing the screws.
I'll like tobuy a new display, but it is impossible for me, do you have the name, or a reference number?
I’ll like to buy a new LCD/ display, but It is for me, do you have the name, or a reference number?
I’m searching for a replacement display, too.
Sharp LS013B7DH03
La pantalla no parece la misma con la referencia que distes???
Me puedes enviar con seguridad la referecia de la pantalla Lcd para el polar v800.MUCHAS GRACIAS
DISPLAY # ????????
wilsoncr_4@hotmail.com
Lift the display from the board from the top side of the watch, revealing the display connectors underneath.
Cual es la referencia del display???
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Using tweezers, gently pull the display wiring out of the two connectors that attach the display to the motherboard.
The connectors must first be opened by turning the white levers up.
crwdns2947412:015crwdne2947412:0
Please tell me where can I found spare parts for polar v800 ( motherboard,display)
Thank you
Por sin la encontré. Lleva una Sharp LS013B7DH03
Please tell me where can I found spare parts for polar v800 ( motherboard,display, also the case and waterproof seal )
Thank you
I need to bought a lcd for this watch, someone knows where i can buy it ? Best regards
Same question as above.
I need to buy a lcd display, too. Does anyone know where to buy?
good morning. could you get the v800 display? do you know where is it possible to get? thank you
SERGIO -
Same question here. Do you guys know if Polar sells spare parts? I just need the top of the casing.
Por favor, dígame dónde puedo encontrar repuestos para polar v800 (Carcasa, pila…)
bonsoir .est ce que vous pouvez me dire ou je peu trouver l’afficheur merci
where i can buy this lcd display ?thanks….
Where can i buy that screen? Thanks
Good tutorial, but it is useless if you cannot get the display replacement.
Hello.Thanks for your video. Just let me know where can I find an LCD for my broken V800 Polar.Thanks
Sharp LS013B7DH03
Este display NO IS CORRECT
