PlayStation Vita Wireless Card Replacement
  1. PlayStation Vita Wireless Card Replacement, Case Separation: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PlayStation Vita Wireless Card Replacement, Case Separation: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Power off and remove the memory card.
    • Using a Phillips #00 screwdriver, remove the four 6.4mm screws on the back casing.
  2. PlayStation Vita Wireless Card Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 PlayStation Vita Wireless Card Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 PlayStation Vita Wireless Card Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using your fingernail or a spudger, pry open the accessory port cover on the top of the device.
    • Using a Phillips #00 screwdriver, remove the two 5.4mm screws hidden beneath the accessory port cover.
  3. PlayStation Vita Wireless Card Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PlayStation Vita Wireless Card Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 5.4mm Phillips #00 screws on the bottom of the device near the charging port.
  4. PlayStation Vita Wireless Card Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 PlayStation Vita Wireless Card Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 PlayStation Vita Wireless Card Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Beginning at the sides of the device, use a plastic opening tool to separate the front and rear cases.
    • Continue working your way around the device gently prying it open.
    • There are still wires holding the front and rear cases together. You may damage the connections if you yank the cases completely apart.
  5. PlayStation Vita Wireless Card Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PlayStation Vita Wireless Card Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently separate the two cases, minding the battery and the touch screen controller connectors holding the two cases together.
  6. PlayStation Vita Wireless Card Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a spudger, free the touch screen controller flex cable by gently prying up the connection.
  7. PlayStation Vita Wireless Card Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Free the battery cable by gently prying up on the connection with a spudger.
  8. PlayStation Vita Wireless Card Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Separate the front and rear cases.
  9. PlayStation Vita Wireless Card Replacement, Wireless Card: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 PlayStation Vita Wireless Card Replacement, Wireless Card: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 PlayStation Vita Wireless Card Replacement, Wireless Card: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the pointy end of the spudger, disconnect the three antenna cable connectors on top of the wireless card.
    • Deroute the antenna cables so that they are out of the wireless card casing. Rest the wires out of the way.
  10. PlayStation Vita Wireless Card Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PlayStation Vita Wireless Card Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Hook the spudger beneath the tab on the wireless card casing and release the tab.
    • Peel up and remove the wireless card casing.
  11. PlayStation Vita Wireless Card Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PlayStation Vita Wireless Card Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 4.4mm Phillips #00 screws on the wireless card.
    • The wireless card will naturally pop out at an angle.
    • Pull out the wireless card.
Brittany McCrigler
crwdns2935283:003/05/12crwdne2935283:0
90,211 crwdns2915208:0crwdne2915208:0
crwdns2935297:0142crwdne2935297:0
Staff
crwdns2931471:0120crwdne2931471:0
crwdns2935297:023,249crwdne2935297:0
crwdns2947412:05crwdne2947412:0
i am takig my vita apart (moving all boards/chips into new oled lcd screen/ front part) and am having trouble taking the wifi chip out in order to take out the right button board, the screw closest to the right button board is i think stripped, is there an easy and non harming way to the motherboard of taking that screw out?
Saul Calderon - crwdns2934203:0crwdne2934203:0
Rubber band .
Duck -
umm, just took mine apart and there isnt a card nor a card holder.... what?
Joe The total Lord - crwdns2934203:0crwdne2934203:0
Then you have the Wi-Fi only version. Only the model with the 3G modem actually has that slot. This part is the 3G modem module. The actual Wi-Fi chip is on the mainboard not as a separate module.
ccfman2004 -
Ask if I got this card and I can build a console without that module. Ask if I got this card and I put together a console without that wifi module, can the console work?
Fernando Olivares - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 62
crwdns2936753:030crwdne2936753:0 238
crwdns2942667:0crwdne2942667:0 15,917
