PlayStation Vita Start/Select Button Replacement
    1. PlayStation Vita Start/Select Button Replacement, Case Separation: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PlayStation Vita Start/Select Button Replacement, Case Separation: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Power off and remove the memory card.
      • Using a Phillips #00 screwdriver, remove the four 6.4mm screws on the back casing.
    2. PlayStation Vita Start/Select Button Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 PlayStation Vita Start/Select Button Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 PlayStation Vita Start/Select Button Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Using your fingernail or a spudger, pry open the accessory port cover on the top of the device.
      • Using a Phillips #00 screwdriver, remove the two 5.4mm screws hidden beneath the accessory port cover.
    3. PlayStation Vita Start/Select Button Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PlayStation Vita Start/Select Button Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the two 5.4mm Phillips #00 screws on the bottom of the device near the charging port.
    4. PlayStation Vita Start/Select Button Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 PlayStation Vita Start/Select Button Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 PlayStation Vita Start/Select Button Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Beginning at the sides of the device, use a plastic opening tool to separate the front and rear cases.
      • Continue working your way around the device gently prying it open.
      • There are still wires holding the front and rear cases together. You may damage the connections if you yank the cases completely apart.
    5. PlayStation Vita Start/Select Button Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PlayStation Vita Start/Select Button Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Gently separate the two cases, minding the battery and the touch screen controller connectors holding the two cases together.
    6. PlayStation Vita Start/Select Button Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Using a spudger, free the touch screen controller flex cable by gently prying up the connection.
    7. PlayStation Vita Start/Select Button Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Free the battery cable by gently prying up on the connection with a spudger.
    8. PlayStation Vita Start/Select Button Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Separate the front and rear cases.
    1. PlayStation Vita Start/Select Button Replacement, Wireless Card: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 PlayStation Vita Start/Select Button Replacement, Wireless Card: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 PlayStation Vita Start/Select Button Replacement, Wireless Card: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Using the pointy end of the spudger, disconnect the three antenna cable connectors on top of the wireless card.
      • Deroute the antenna cables so that they are out of the wireless card casing. Rest the wires out of the way.
    2. PlayStation Vita Start/Select Button Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PlayStation Vita Start/Select Button Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Hook the spudger beneath the tab on the wireless card casing and release the tab.
      • Peel up and remove the wireless card casing.
    3. PlayStation Vita Start/Select Button Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PlayStation Vita Start/Select Button Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the two 4.4mm Phillips #00 screws on the wireless card.
      • The wireless card will naturally pop out at an angle.
      • Pull out the wireless card.
    1. PlayStation Vita Start/Select Button Replacement, Right Shoulder Button: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 PlayStation Vita Start/Select Button Replacement, Right Shoulder Button: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 PlayStation Vita Start/Select Button Replacement, Right Shoulder Button: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Pry up the right shoulder button casing with a spudger and set it aside.
    2. PlayStation Vita Start/Select Button Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the translucent, plastic right shoulder button cover.
    3. PlayStation Vita Start/Select Button Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 PlayStation Vita Start/Select Button Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 PlayStation Vita Start/Select Button Replacement: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Release the right shoulder button flex cable socket by using a spudger to gently pry open the tab.
      • Using tweezers, slide the flex cable out of the socket.
    4. PlayStation Vita Start/Select Button Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PlayStation Vita Start/Select Button Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Using a spudger, gently peel up the right shoulder button from the light adhesive connecting it to casing.
    1. PlayStation Vita Start/Select Button Replacement, Right Button Board: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PlayStation Vita Start/Select Button Replacement, Right Button Board: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Using the pointy end of a spudger, detach the antenna cable on the right button board.
      • Remove the antenna cable.
    2. PlayStation Vita Start/Select Button Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PlayStation Vita Start/Select Button Replacement: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Using a spudger, pry up and release the ZIF socket on the right button board.
      • Gently pull the flex cable out of the socket. Rest the flex cable out of the way.
    3. PlayStation Vita Start/Select Button Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 PlayStation Vita Start/Select Button Replacement: crwdns2935265:018crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 PlayStation Vita Start/Select Button Replacement: crwdns2935265:018crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Release the tab on the small flex cable socket by prying up the tab with a spudger.
      • Using tweezers, gently pull the flex cable out of the socket. Rest the flex cable out of the way.
    4. PlayStation Vita Start/Select Button Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 PlayStation Vita Start/Select Button Replacement: crwdns2935265:019crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 PlayStation Vita Start/Select Button Replacement: crwdns2935265:019crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove the two 5.0mm Phillips #00 screws from the metal bracket securing the right button board to the motherboard.
      • Remove the metal bracket, using a spudger as necessary to lift it out.
    5. PlayStation Vita Start/Select Button Replacement: crwdns2935265:020crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 PlayStation Vita Start/Select Button Replacement: crwdns2935265:020crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 PlayStation Vita Start/Select Button Replacement: crwdns2935265:020crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Use a spudger to free the right button board by prying up from the bottom right corner of board.
      • Gently lift the right button board out.
    1. PlayStation Vita Start/Select Button Replacement, Start/Select Button: crwdns2935265:021crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 PlayStation Vita Start/Select Button Replacement, Start/Select Button: crwdns2935265:021crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 PlayStation Vita Start/Select Button Replacement, Start/Select Button: crwdns2935265:021crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Using tweezers, peel the start/select button off the back case.
Brittany McCrigler
crwdns2935283:003/05/12crwdne2935283:0
91,069 crwdns2915208:0crwdne2915208:0
crwdns2935297:0142crwdne2935297:0
Staff
crwdns2935297:086,241crwdne2935297:0
So I hit a roadblock at step 11, it seems some of these devices have security screws with no specific bit (or at least not one I could find) on the network card, so if you plan on attempting this repair please check your network card before doing so as you may need to perform some extra steps (such as cutting at the thing with a dremel if you're comfortable with that...) before moving forward. Here's what I'm referring to
Celestial Nomad - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:07crwdne2936753:0 49
crwdns2936753:030crwdne2936753:0 113
crwdns2942667:0crwdne2942667:0 9,912
