PlayStation Move Battery Replacement
crwdns2942287:0crwdne2942287:0This guide will show the steps to dismantle the move controller and remove the battery in order to have it replaced.
crwdns2944105:0crwdne2944105:0
Using a Phillips #0 screwdriver, remove the four 10mm screws located on the back of the device.
Insert the plastic opening tool at the indent.
Gently use a forward and backward motion to safely pop open the cover.
Using your hands to further pull it apart.
Once the device is opened, lift the battery out of the black plastic holder.
You can disconnect the back/trigger assembly ribbon cable at this point by proceeding to Steps 13/14 (without the other steps for disassembly as they are unnecessary for replacing just the trigger).
Using a Phillips head screwdriver, remove the 9mm screw located to the right of the battery, which is connected to the inner plastic frame.
Using the plastic opening tool carefully take out the grey cylindrical piece (vibrator) that is also attached to a wire.
Gently pull out the small grey cylindrical piece (vibrator).
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Using tweezers, remove the small piece with a cylindrical top that is located to the left of the inner plastic frame.
Using one hand to hold the device, and the other hand to squeeze the inner plastic frame.
Remove by squeezing the inner plastic frame, lift and pull it towards you.
Gently pull on the white piece connecting the battery and the connector.
crwdns2935229:09crwdne2935229:0
crwdns2947412:05crwdne2947412:0
When putting the plastic battery rig back in on my second time doing this, I bent one of the little plastic pins that fits into a hole in the PCB. Definitely want to be careful with that. To make it a bit easier, I unscrewed the bottom port PCB part of the way so I could take the bottom plastic housing and put the plastic battery rig in straight. It made it a lot easier.
No need to take out the motor, just use sharp tweezers and grab the connector (NOT the wires) and with small wiggling pull it out. Worked for mine.
Worked great! Thanks for this. I did not need to take out the black battery / motor piece. Tweezers worked great to remove and install the battery cable
Any recommended online / physical store to buy new batteries for this because ifixit doesn’t have them?
Je suis pas capable de coupler les manettes et quand j essaie de l ouvrir la lumière ne reste pas allumée. Sa se peut tu que les batteries sont finis. Je viens de l acheter usager
