If your PlayStation is displaying faulty video, emitting choppy audio, or just isn’t booting properly, the motherboard may need to be replaced. This guide will take you through the process of replacing the motherboard, which houses all of the processors and A/V connectors.
Note: This repair is demonstrated on a SCPH-1001 model. The process may differ slightly if you have a later model.
Turn the console upside down and remove the five 15.8 mm-long Phillips #1 screws.
While holding the top and bottom halves of the console together, flip the console back over. Lift the top cover straight up to remove it.
Remove five Phillips #1 screws securing the metal shield to the controller ports:
Two 14 mm screws
Three 8 mm screws
Doesn't apply to my 7502 model.
Only remove the two 14mm screws.
Lift the metal shield straight up to remove it.
Pull the controller port's ribbon cable straight up and out of its socket on the motherboard to disconnect it.
Only remove the ribbon cable from the centre of the two ports.
Lift the controller ports straight up and out of the bottom case.
Pull the optical drive power cable straight up and out of its socket on the motherboard to disconnect it.
I broke the optical drive power cable’s socket off from the motherboard! How to put it back on?
Please try not to pull via the wires as you run the risk of breaking the cable, in which if you have a replacement reader like mine you will need this cable again as it didn’t come with one. I recommend wiggling it from each side. Seems to work for me.
Use the flat end of a spudger to lift up and unlock one side of the data cable's connector on the motherboard. Repeat this step on the other side of the connector.
Gently pull the optical drive data cable straight up and out of its socket on the motherboard to disconnect it.
While I was pulling this cable, the whole connector came off the motherboard (the white part that's supposed do stay on the motherboard)... How can I fix it?
Do I solder it or what?
Same exact problem with pulling the entire connector off the motherboard. What do i do?
Yes, could try clean and re-solder, and do a proper re-work job.
help! i just had the same problem! someone was able to solve it ???
Lift the optical drive straight up to remove it.
Pull the power supply cable straight up and out of its socket on the motherboard to disconnect it.
Remove the five 14 mm-long Phillips #1 screws from the motherboard's metal shield.
From the left side, lift up the metal shield and rotate it about its right edge, opening it like a book.
Remove the three 14 mm-long Phillips #1 screws securing the motherboard to the bottom case.
Lift the motherboard out of the bottom case.
crwdns2935229:030crwdne2935229:0
Hi there.
Here i can buy that copper tape from the right of the metal shield ?
Thkx in adv
Excelente guía, esto ayuda a muchos para aprender a reparar y no hacer gastos innecesarios.
Thanks for sharing. Could you make a tutorial about common Board damage and how to fix it?
The SCPH-9001 model does not have the Parallel Port panel to remove.
Aislinn - crwdns2934203:0crwdne2934203:0
