Follow this guide to replace a broken or faulty fan in your PlayStation 5 Slim.
If your fan isn't spinning, is spinning very slowly, or is making very loud noises, you may need to replace it.
You can also use this guide to clean out a dusty or dirty fan.
Before purchasing a replacement fan, it's a good idea to remove your current fan and clean off any dust, dirt, hair, or grime that may have accumulated—it's possible this alone is the problem. If the fan still shows signs of being faulty after cleaning, then consider purchasing a replacement.
Shut down your console and unplug all cables and accessories.
Remove any stands supporting your device and lay it down.
Lay your PlayStation on its side so the right side covers are facing up.
Firmly pull up the front edge of the smaller, upper cover to release the clips.
Remove the cover.
crwdns2935267:0crwdne2935267:0Tesa 61395 Tape$5.99
Use your fingers to remove the plastic cover.
Gently pull the fan cables out from under their plastic clip on the frame.
Firmly grip the fan cables' white connector head and pull it straight up and out of its socket.
crwdns2935267:0crwdne2935267:0FixMat$36.95
Use a T8 Torx Security screwdriver to remove the four screws securing the fan:
One 31.2 mm‑long screw
Two 21.3 mm‑long screws
One 11.6 mm‑long screw
Los tornillos son M2, M2.5 o M3 disculpe esque mis tornillos se me han barrido y quería saber que medida son de antemano gracias.
Use your fingers to grab the fan by its vents and lift it straight up to remove it.
Cooling Fan Replacement For Sony PS5 Slim 19 Blades check kasynparts
