Follow this guide to replace a broken or faulty disc drive in your PlayStation 5 Slim. You can also use this guide to install a disc drive if your PlayStation doesn't have one, but you'll need a new console cover that will fit over the drive.
If you're having issues playing disc-based games, Blu-rays, or DVDs, you may need to replace your disc drive.
An internet connection is required to set up and pair your new disc drive.
Shut down your console and unplug all cables and accessories.
Remove any stands supporting your device and lay it down.
crwdns2931653:02crwdne2931653:0 Remove the disc drive cover
crwdns2944588:02crwdnd2944588:0crwdnd2944588:0crwdne2944588:0
Firmly pull up the front edge of the disc drive cover to release the clips.
Remove the cover.
crwdns2931653:03crwdne2931653:0 Remove the disc drive
crwdns2944588:03crwdnd2944588:0crwdnd2944588:0crwdne2944588:0
Use the cutout on the bottom right corner of the disc drive to lift its right edge and disconnect it.
Remove the disc drive.
Place the hooks on the drive's left edge into their cutouts on the frame and lay the drive onto your PlayStation.
Firmly press the right edge into place so the disc drive connector slides into its socket on the bottom right corner.
We really need to know a part # or approximation for the disk drive that may be compatible. As far as I understood it the PS5 Pro only had the option for a private external officially signed disk drive.
Additionally, could you recommend a replacement shell as the PS5 PRO’s original shell wouldn’t have the additional space needed to accommodate the new drive.
Hi Scott! Here is Sony's official replacement part (compatible with the PS5 Slim or Pro). It also comes with a new shell that will accommodate the disc drive.
crwdns2947412:08crwdne2947412:0
Spencer, thank you for all your efforts in making this task manageable to all of us rtr novices!
Deeno
once a disc drive has been paired with a system , can we use the same disc drive on another ps5 system ?
Yes you can! You should be prompted to register the drive with your device, which will require an internet connection.
Where can I get a new disk drive in Australia?
Also. Is it the same drive as you would add to the digital version
Yes. It is the same disc drive for PS5 Slim digital.
Ennis -
I'm not hearing the 'click' when I install the drive. And the PlayStation is not even detecting that a drive has been installed, I'm not getting any power to it or anything. Could it be seated incorrectly or something??
Hi Arrien! Yes, I would check that it's properly seated and make sure there's no dirt/dust/grime in the connector or socket.
