Follow this guide to replace the CMOS board in your PlayStation 5 Pro.
If you only need to replace the CMOS battery itself, follow this guide.
The CMOS board is responsible for storing date and time information for your console. If your PlayStation's date and time are out of sync or not saving, you may need to replace the CMOS board.
Shut down your PlayStation and unplug all cables and accessories.
Remove any stands supporting your console and lay it down so the right side is facing up.
To remove a cover, firmly pull up the front edge to release the clips.
Remove the cover.
Use the same process to remove the three remaining covers.
crwdns2935267:0crwdne2935267:0FixMat$36.95
Use a Phillips screwdriver to remove the 17.1 mm‑long screw securing the expansion slot cover.
Use your fingers to lift the expansion slot cover near the notch by the screw hole and remove it.
crwdns2935267:0crwdne2935267:0Tesa 61395 Tape$5.99
Use your fingers to remove the plastic cover hiding the fan cables connector.
Gently pull the fan cables out from under their plastic clip on the frame.
Firmly grip the fan cables' white connector head and pull it straight up and out of its socket.
Use a T8 Torx Security screwdriver to remove the four screws securing the fan:
One 31.7 mm‑long screw
Two 21.5 mm‑long screws
One 11.5 mm‑long screw
Use your fingers to grab the fan by its vents and lift it straight up to remove it.
Insert the fan so its cables are near their connector.
A tamper-evident sticker hides one of the right‑side inner shell screws.
Use tweezers to peel up the sticker until you can access the screw underneath.
Use your fingers to unclip and remove the plastic grille near the fan recess.
Use a T8 Torx Security screwdriver to remove the 10 screws securing the right‑side inner shell:
Four 18.8 mm‑long screws
Two 18.6 mm‑long screws
Four 31.7 mm‑long screws
Lift the right‑side inner shell straight up and remove it.
Use a pair of angled tweezers to firmly grip the sides of the CMOS board connector, holding the tweezers as close to the connector as possible to get a good grip.
Pull the connector straight up and out of its socket to disconnect it.
Use your fingers to lift the CMOS board off the small metal nubs and pull it toward the center of your console to remove it.
