PlayStation 3 Hard Drive Replacement
  1. PlayStation 3 Hard Drive Replacement, Hard Drive Backup: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PlayStation 3 Hard Drive Replacement, Hard Drive Backup: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • If you need to backup the data on your current hard drive, follow the instructions in this step. Otherwise, continue to the next step.
    • On a Windows/OS X/Linux machine, format an external USB hard drive (with enough space available to backup your current hard content) into the FAT32 file system.
    • Make sure it's formatted FAT32. The Playstation 3 backup utility will not recognize any other file system.
    • Connect your formatted hard drive to the Playstation 3 through a USB port and power the console up.
    • Navigate the XMB to the 'Settings' menu and select 'System Settings'
    • Select the 'Backup Utility' function to create a backup of your data - this can take up to 2 hours if you have a lot of data on the PS3.
  2. PlayStation 3 Hard Drive Replacement, Hard Drive: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PlayStation 3 Hard Drive Replacement, Hard Drive: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the flat end of a spudger to pry the hard drive door away from the lower case.
    • Remove the hard drive door from the PS3.
  3. PlayStation 3 Hard Drive Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the blue 8 mm Phillips screw securing the hard drive cage to the chassis.
  4. PlayStation 3 Hard Drive Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 PlayStation 3 Hard Drive Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 PlayStation 3 Hard Drive Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Grab the hard drive pull tab and pull the hard drive toward the front face of the PS3.
    • Pull the hard drive assembly out of the PS3.
  5. PlayStation 3 Hard Drive Replacement, Hard Drive: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PlayStation 3 Hard Drive Replacement, Hard Drive: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    Screw Extracting Pliers
    $19.99
    • Remove the four 4.3 mm Phillips screws securing the hard drive cage to the hard drive.
    • These 4 screws can sometimes be very difficult to remove. If you strip the heads our Screw Extracting Pliers remove the damaged screws nicely.
  6. PlayStation 3 Hard Drive Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the hard drive from its steel cage.
    • If you're installing a new hard drive into your PS3, use this guide to restore the data you backed up.
crwdns2935229:0159crwdne2935229:0
Walter Galan
702,127 crwdns2915208:0crwdne2915208:0
crwdns2935297:01,203crwdne2935297:0
My problem is my ps3 don't play disc
Elton Boyd - crwdns2934203:0crwdne2934203:0
How is this in any way related to a HDD replacement guide?
Dirk Ronsmans -
You should probably check out the guides for your console then. This one is not for your model.
Lynn Fraaza -
help please inbox me at heinobad4@gmail.com
Heino Badenhorst - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 32
crwdns2936753:07crwdne2936753:0 242
crwdns2936753:030crwdne2936753:0 1,003
crwdns2942667:0crwdne2942667:0 243,627
