PlayStation 2 Optical Disc Drive Laser Assembly Replacement
  1. PlayStation 2 Optical Disc Drive Laser Assembly Replacement, Top Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 PlayStation 2 Optical Disc Drive Laser Assembly Replacement, Top Cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 PlayStation 2 Optical Disc Drive Laser Assembly Replacement, Top Cover: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip the PlayStation 2 over so it lays with the bottom of the device facing upwards.
    • Use the flat edge of a metal spudger to pry the eight flat screw covers out.
    • Remove the following eight screws securing the top cover to the bottom case:
    • Four 55.4 mm Philips screws
    • Four 18.0 mm Phillips screws
    Before proceeding to step 2, Take a look at your PS2, some PS2's have 10 screws (and screw covers) instead of 8 (i found them underneath the optical drive), these instructions have mislead me and i ended up breaking my top cover for my PS2.
    Tristan - crwdns2934203:0crwdne2934203:0
    Ich möchte daraufhin weisen, daß es bei der SCPH-50004 zwei verschiedene Schraubabdeckungen gibt.
    4x Kreuzförmig 4x rechteckig
    Sowie eine silberne schraube die sich an der unterseite aufhöhe des Reset-Knopfes befindet.
    Christian Lehnhardt - crwdns2934203:0crwdne2934203:0
  2. PlayStation 2 Optical Disc Drive Laser Assembly Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Some models have a different number of screws and feet. Remove all the feet and screws in the bottom of the case.
    • The 10 screw model has 6 screws in the bottom-most portion and 4 in the upper tray.
  3. PlayStation 2 Optical Disc Drive Laser Assembly Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Peel the warranty sticker (located next to the main power switch) straight away from the case.
    • To avoid activating the VOID that may come up, heat it carefully to remove and replace it clean
  4. PlayStation 2 Optical Disc Drive Laser Assembly Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PlayStation 2 Optical Disc Drive Laser Assembly Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the PlayStation 2 back to its original upside position.
    • Lift the top cover off the bottom case.
    • To facilitate the removal, it is recommended to pry open the half closer to the power switch first while rocking the top cover towards the front of the bottom case.
    • Carefully remove the power cord that attaches the top and bottom halves by disconnecting the power cord assembly from the top case.
    If you have a 5000x model, then the power and reset buttons are attached to the console, not the lid. Therefore there won’t be a cord
    ARandomGuy231 - crwdns2934203:0crwdne2934203:0
  5. PlayStation 2 Optical Disc Drive Laser Assembly Replacement, Optical Disc Drive Laser Assembly: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PlayStation 2 Optical Disc Drive Laser Assembly Replacement, Optical Disc Drive Laser Assembly: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four 6.4 mm Phillips screws securing the top lid of the optical disc drive.
    • Lift and remove the lid from the optical disc drive.
    The next image skips a step; Once you remove the top of the disc drive, the disc tray below it will need to be moved to progress to step 6. To do this, plug the console back in and push the eject button. Be sure to unplug the console again before moving on.
    Gena FM - crwdns2934203:0crwdne2934203:0
  6. PlayStation 2 Optical Disc Drive Laser Assembly Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 7.2 mm Phillips black screws securing the metal silver rails that hold the laser in place.
    where can someone buy replacements for these in this day and age
    Charles thekinglov - crwdns2934203:0crwdne2934203:0
    eBay is a good place for it
    Nicholas -
  7. PlayStation 2 Optical Disc Drive Laser Assembly Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your fingernail to flip up the retaining flap on the optical disc drive laser ribbon cable.
    • Be sure you are prying up on the movable retaining flap, not the socket itself.
    • Pull the optical disc drive laser ribbon cable straight away and out of its socket.
    • If you maneuver the unscrewed ends of the metal rails upwards, the laser will slide out.
crwdns2935229:036crwdne2935229:0
jwyoung
crwdns2935283:011/04/09crwdne2935283:0
2 938 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 19-1, Maness Fall 2009 crwdns2935289:0Cal Poly, Team 19-1, Maness Fall 2009crwdne2935289:0
CPSU-MANESS-F09S19G1
crwdns2935297:035crwdne2935297:0
crwdns2947412:08crwdne2947412:0
just did the laser replacement, however the playstation still identifies "no data" when game is inserted. it says "reading disk" for a few seconds then nothing else happens. thought?
Danyal Fatmi - crwdns2934203:0crwdne2934203:0
Have you removed the security solder blob? All new Lenses have this somewhere in the circuitry.
Carlos Bragatto -
Number 1 Ifixit the class world,
Mohsen - crwdns2934203:0crwdne2934203:0
I noticed that many times when you replace a lens it throws of the rotary motor. Some ps2 consoles have only 1 hex adjustment yet others have 2. If you have the covers off and just replaced the lenses you should always plug it back in w/ the top off still and adjust it until you see the disc spinning rapidly and laser is moving back and forth. Another way for calibrating is to remove said disc and if lens and ribbon move all the way forward and all the way back 3 or more times then you are almost done. At that point plug in tv chord and place in a disc if the PlayStation 2 logo comes on and disappears in less than 3 seconds carefully replace all parts and your good to go.
Raymond - crwdns2934203:0crwdne2934203:0
Could you please add the parts you would need to replace this to the parts portion.
Nice guide by the way.
Alexander Wiand - crwdns2934203:0crwdne2934203:0
My ps2 doesn't spin the cd what can i do to fix it
ziad ashraf - crwdns2934203:0crwdne2934203:0
I have two PlayStation 2 SCPH-50003. Both used, don't have any mode chip on it! One of them play all game PlayStation/ PlayStation 2 black blue and silver discs.
The other played SSX 3 and Tomb raider legend but videos where slow and gameplay had problems. Just tested it and minutes later stoped working.
I Ibought2 lenses KHS-400C. I removed the solder spot from both of lenses. I tried both of them and none of them worked! I tried from the other working PlayStation 2 and didn't worked either! I tried all 4 KHS-400C on the working console and they all worked!
What else can cause Disc read error? Moreover I replaced the drive with motors and eject mechanism from the working one to the non working with no change!
gUru0026 - crwdns2934203:0crwdne2934203:0
Thx i have a problem with that's
Marek Darga - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 11
crwdns2936753:07crwdne2936753:0 117
crwdns2936753:030crwdne2936753:0 506
crwdns2942667:0crwdne2942667:0 84,853
