Plantronics CS50 Headset System Reset
crwdns2942287:0crwdne2942287:0If your headset had been working great but suddenly started producing static or distorted sounds, you may need to reset your headset. Follow these instructions:
Press and hold both the call control button and the listening volume/mute button for five seconds.
When the talk indicator light blinks, release both buttons.
Unplug the base unit's power source for ten seconds.
Plug the power source back in.
Great fix. I was about to spend $200 on a new set. Thanks.
I had a constant buzzing sound from the unit. I did what you recommended and could not stop it. Then I discovered that my handset also had the same buzzing sound so I unplugged the phone line and power cord (to the main phone unit) and it cleared up!
I've got a unit that is getting no sound to or from the earpiece at all, though the lifter still lifts when I hit the answer button. I'll try this reset before I order a replacement set.
I have the C053 model and have cleaned headset and base and can not get it to charge. I have noticed over the past few weeks that it will only stayed charged from 800 am to 100 pm. I have disconnected and restarted also. Any other suggestions?
Diane
