Pixel 9 Battery Disconnection
crwdns2862623:0crwdne2862623:0
crwdns2948751:0crwdne2948751:0
  1. Pixel 9 Battery Disconnection, Prepare your Pixel for disassembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Pixel 9 Battery Disconnection, Prepare your Pixel for disassembly: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Pixel 9 Battery Disconnection, Prepare your Pixel for disassembly: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Let your Pixel's battery drain below 25% before starting this repair. A charged lithium‑ion battery may catch fire if damaged.
    • Unplug all cables from your phone.
    • Completely power off your phone.
    • Press the power and volume up buttons at the same time to bring up the shutdown menu.
  2. Pixel 9 Battery Disconnection, Adhesive information: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Pixel 9 Battery Disconnection, Adhesive information: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Pixel 9 Battery Disconnection, Adhesive information: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Adhesive secures the perimeter of the back glass to the frame.
    • When separating the adhesive, don't insert your tool more than 3 mm under the back glass to avoid damaging the internal components.
    • To help, measure and mark 3 mm from the tip of an opening pick with a permanent marker.
    • If your screen or back glass is badly cracked, a suction cup may not perfectly adhere.
    • Lay overlapping strips of packing tape over the glass to protect yourself and make disassembly easier. Ensure there's a smooth area near the bottom edge that's large and smooth enough for a suction cup to stick to.
  3. Pixel 9 Battery Disconnection, Apply a suction handle: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Pixel 9 Battery Disconnection, Apply a suction handle: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Place a suction handle at the bottom edge of the back glass, as close to the edge as possible.
    • Push down to attach the suction cup.
  4. Pixel 9 Battery Disconnection, Insert an opening pick: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Pixel 9 Battery Disconnection, Insert an opening pick: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Pixel 9 Battery Disconnection, Insert an opening pick: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull up on the suction handle with strong, steady force to create a small gap under the back glass.
    • Insert the tip of an opening pick into the gap.
  5. Pixel 9 Battery Disconnection, Separate the back glass adhesive: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Pixel 9 Battery Disconnection, Separate the back glass adhesive: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Pixel 9 Battery Disconnection, Separate the back glass adhesive: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the opening pick back and forth along the bottom edge to separate the adhesive securing it.
    • Remember: don't insert the opening pick deeper than 3 mm.
  6. Pixel 9 Battery Disconnection: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Pixel 9 Battery Disconnection: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Pixel 9 Battery Disconnection: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the opening pick around the perimeter of the phone, slicing the rest of the adhesive.
  7. Pixel 9 Battery Disconnection: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Pixel 9 Battery Disconnection: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Pixel 9 Battery Disconnection: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • With most of the adhesive separated, lightly twist the opening pick at the bottom edge to lift the back glass up until you can grip it with your fingers.
    • Use the opening pick to separate any remaining sections of adhesive securing the back glass.
  8. Pixel 9 Battery Disconnection, Remove the back glass: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the back glass.
    • During reassembly:
    • Now is a good time to test your phone before sealing it up. Power it on and check that it works. Power it back down before you continue reassembly.
    • Follow this guide to apply new adhesive and install your back glass.
  9. Pixel 9 Battery Disconnection, Remove the upper board cover: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    FixMat
    $36.95
    • While the Pixel 9 uses Torx Plus screws, standard Torx bits also work. Make sure to apply constant, downward force to prevent stripping.
    • Use a 3IP Torx Plus driver to remove the single 5.4 mm‑long screw securing the upper board cover.
  10. Pixel 9 Battery Disconnection: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Pixel 9 Battery Disconnection: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a pair of tweezers to remove the upper board cover.
  11. Pixel 9 Battery Disconnection, Remove the midframe: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a 3IP Torx driver to remove the five screws securing the midframe and wireless charging coil:
    • Four 5.4 mm-long screws
    • One 2.2 mm-long screw
  12. Pixel 9 Battery Disconnection, Peel up the flash cable: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Pixel 9 Battery Disconnection, Peel up the flash cable: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a pair of tweezers to peel the flash cable off of the metal midframe.
  13. Pixel 9 Battery Disconnection, Remove the midframe: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Pixel 9 Battery Disconnection, Remove the midframe: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the midframe, wireless charging coil, and NFC assembly.
  14. Pixel 9 Battery Disconnection, Disconnect the battery: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Pixel 9 Battery Disconnection, Disconnect the battery: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the tip of a spudger to pry up and disconnect the battery connector.
Carsten Frauenheim
156,616 crwdns2915208:0crwdne2915208:0
crwdns2935297:0439crwdne2935297:0
Staff
crwdns2931471:0123crwdne2931471:0
crwdns2935297:023,828crwdne2935297:0
crwdns2936753:030crwdne2936753:0 3
crwdns2942667:0crwdne2942667:0 62
