If your Philips Somneo light is faulty or not working, access the LED with this guide. For this guide, you will need a plastic opening tool/pick, a plastic and metal spudger, and a Phillips #00 screwdriver head. You will not need to do any difficult steps, but when removing the motherboard, be sure to disconnect the cables carefully.
Remove the four silicone feet on the bottom plate.
Remove the following Phillips screws from the bottom plate:
Two 9 mm screws
Two 13 mm screws
Remove the bottom plate from the device.
Disconnect the antenna connector by pulling it directly out of its port.
Remove the antenna.
Remove the four 9 mm Phillips screws securing the motherboard.
Gently pull the motherboard down until the cables are visible.
Remove each cord by gently disconnecting each connector with your hand.
Continue gently removing each cord with you hand.
Finish gently removing the final cord attached to the motherboard to successfully remove the motherboard.
Use an opening pick to pry underneath the plastic covering the edges of the screen.
Place an opening tool in the space made between the screen and this plastic piece and pry up, working around the length of this circular piece to significantly loosen it.
The panel should be loosened significantly enough to be pulled off the main body, revealing the edges of the screen.
Remove the two 13 mm Phillips #0 screws on the bottom edges of the screen.
Remove the 9 mm Phillips #0 screws on the upper edge of the screen.
On the back of the screen, remove the four 9 mm Phillips #00 screws, disconnecting the LED assembly.
Using a metal spudger, scrape underneath this adhesive and pry up, freeing the cable from the body. Repeat this for the other cable to free the LED.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
