Philips Respironics System One REMstar Circuit Board Replacement
Rachel Ross
crwdns2944107:0crwdnd2944107:0Rachel Rosscrwdnd2944107:0crwdnd2944107:0crwdnd2944107:02crwdnd2944107:0crwdne2944107:0
crwdns2944111:0N'w 9, 2020crwdne2944111:0
crwdns2931287:010crwdne2931287:0
crwdns2937801:0crwdne2937801:0
crwdns2942287:0crwdne2942287:0
This guide will show you the process of removing the circuit board from the Philips Respironics System One REMstar ventilator. The circuit board controls all of the operations of the device, including critical pressure and volume managements, so it’s key that the board is functioning correctly if the device is in use on a patient. Be sure to run thorough diagnostics tests on the device after a replacement has been made to ensure the device is functioning as intended.
  1. Philips Respironics System One REMstar Circuit Board Replacement, Circuit Board: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the device upside down so that the rubber feet are facing you.
    • Use a Torx TR15 screwdriver to remove the two 46.5mm screws located on the back.
    • Gently separate the panel so the wires are not damaged.
  2. Philips Respironics System One REMstar Circuit Board Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a Torx TR10 screwdriver, remove the seven 13.5 mm screws that are securing the inner casing.
    • Lift out the inner casing.
  3. Philips Respironics System One REMstar Circuit Board Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the motor from the bottom portion of the casing and set it aside.
  4. Philips Respironics System One REMstar Circuit Board Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Philips Respironics System One REMstar Circuit Board Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the side panel by lifting it up out of the base.
    • Remove the grouped wire and wire connector.
  5. Philips Respironics System One REMstar Circuit Board Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Philips Respironics System One REMstar Circuit Board Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the circular piece by popping it off to separate the circuit board from the top cover.
    • No tools should be necessary to complete this action.
  6. Philips Respironics System One REMstar Circuit Board Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Philips Respironics System One REMstar Circuit Board Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Separate the green, red, and white wire connectors from their connections on the circuit board.
Rachel Ross
crwdns2935283:009/16/20crwdne2935283:0
133 crwdns2915208:0crwdne2915208:0
The Citadel Military College of South Carolina, Team S1-G1, Eggleston Fall 2020 crwdns2935289:0The Citadel Military College of South Carolina, Team S1-G1, Eggleston Fall 2020crwdne2935289:0
CMCSC-EGGLESTON-F20S1G1
Do you happen to have a part number or link for replacement pcb?
Kyle Pierce - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 1,107
