Philips HC5450 Disassembly
  1. Philips HC5450 Disassembly, Disassembling a Philips HC5450 1415 /A: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Philips HC5450 Disassembly, Disassembling a Philips HC5450 1415 /A: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Philips HC5450 Disassembly, Disassembling a Philips HC5450 1415 /A: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • First step is to take off the front like you normally do when cleaning.
  2. Philips HC5450 Disassembly, Take off the silver bezel: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Philips HC5450 Disassembly, Take off the silver bezel: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Philips HC5450 Disassembly, Take off the silver bezel: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pry off the silver bezel. This is attached pretty firmly. Start at the front, and go all the way. The front has tabs with a large hook, so it might only fully disassemble when you have pried it loose a long way and you are able to flex the bezel a little.
    • During this step, I broke the last tab of the silver bezel. Too bad, but the bezel is still firmly attached when reassembling.
    I started in the middle by the adjustment wheel and rested my prying tool on the adjustment wheel and lifted the silver bezel
    Göran Israelsson - crwdns2934203:0crwdne2934203:0
  3. Philips HC5450 Disassembly, Take out four T8 screws: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Philips HC5450 Disassembly, Take out four T8 screws: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a T8 Torx driver to remove the four screws.
  4. Philips HC5450 Disassembly, Take apart the body: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Philips HC5450 Disassembly, Take apart the body: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Philips HC5450 Disassembly, Take apart the body: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Undo the top part of the black body. I started at the back. It is retained with clips, but is not as firmly attached as the silver bezel.
  5. Philips HC5450 Disassembly, Take out the PCB and batteries: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Philips HC5450 Disassembly, Take out the PCB and batteries: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Philips HC5450 Disassembly, Take out the PCB and batteries: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The PCB can now be taken out. The connection to the charging pins is not screwed or soldered, but a U-shaped connector that's just retained by friction.
  6. Philips HC5450 Disassembly, Take out the motor and length-adjustment-assembly: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The assembly is held in place by one Torx T8 screw, identical to those from step 3.
    • The ring of the length-adjustment-assembly can slide down. A little pin-and-spring will fall out - don't loose it! It is used to make the "clicking" feedback when rotating the ring.
    • I did not disassemble this assembly any further.
    Hi! what about the small plastic pin with the spring? when I opened it it fell down, I've got it, but I don't know where to put it, mounting it back.
    t.coyote - crwdns2934203:0crwdne2934203:0
crwdns2935229:011crwdne2935229:0
Jurrie
crwdns2935283:005/07/21crwdne2935283:0
667 crwdns2915208:0crwdne2915208:0
crwdns2947412:08crwdne2947412:0
You helped me replace batteries in otherwise completely fine trimmer. Thanks!
Anyway I also snapped the last silver clip...
Marek Ratvaj - crwdns2934203:0crwdne2934203:0
I joined ifixit just to say thank you for this. Trimmer working perfectly other than a dead battery. I just couldn't see how to get into it until I found this guide. Some advice for others:
Use the pry bar around every part of the bezel. I left the very bottom catch attached and broke it pulling on it. On the other hand, if you have to break one catch, that one is the least important.
A credit card makes a very good pry bar.
This battery seems better than the original in several ways: https://www.amazon.co.uk/dp/B0921ZJX11. It is cheaper. It is easier to install. It will likely be easier to uninstall.
Paul Gardiner - crwdns2934203:0crwdne2934203:0
Thanks for your help. All went as you described it - even the small broken pin :-)
Unfortunately I couldn’t replace the batteries, because they are welded to the PCB. Phillips don’t want the lifespan of their devises to be easily extended…
Cedric Marillat - crwdns2934203:0crwdne2934203:0
Just unsolder it from the circuit board. Obviously that requires a soldering iron and a solder sucker, but those are very useful purchases if you don't already own them. If you then replace with the battery I suggest, you wont even need the solder sucker next time you need to do the job.
Paul Gardiner -
Nice and easy to use guide, with quality images. Do you have an image showing how to reinsert the pin-and-spring please?
Mine sprung out, and can't make out how to add it back!
Tyson - crwdns2934203:0crwdne2934203:0
Mine sprung out as well.. There is a hole that the spring+plastic piece sits in, put it in there and move the rotary knob over it such that it stays in place when reassembling..
Fred -
Thank you for the very useful guide! I needed to disassemble the trimmer for changing the weeked battery. I did everything step by step, including the back clip broken :). Waiting now for battery from Amazon.de
Evgeni Stamenov - crwdns2934203:0crwdne2934203:0
Thanks! So for me, I noticed that the motor rotates but the blade would not move sometimes. I would shake it, and then it would "catch on" briefly... I hit the shaft of the motor with some sandpaper and superglue, looks to be working, hope it holds. (I could just pull the metal piece attached to the shaft off, not sure how it is supposed to attach originally - it is a simple round shaft without a key or anything.
Fred - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 14
crwdns2936753:07crwdne2936753:0 59
crwdns2936753:030crwdne2936753:0 258
crwdns2942667:0crwdne2942667:0 7,470
